Page 1167 of 1394 <123 ... 116611671168 ... 139213931394>
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
USB outlet looks very neat.
Where did you connect it in? Keith
Post #752581 20th Jan 2019 12:28pm
Keith5
Post #752582 20th Jan 2019 12:28pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Keith, I just piggy backed it off the factory 12v accessory socket. If you fancy doing the same, I’d recommend siting the USB socket another 1-2cm deeper towards the bulkhead as shown in following photo. That’s because there is an internal plastic rib on the inside of the curvature of the dash that prevented the socket seating squarely until I blindly but judiciously ground a section of the rib away with my dremel.
Post #752584 20th Jan 2019 12:51pm
Nigelpugh7
New suspension testing!
Had 6 hours of off roading for customers this week, so it was time to put the new extreme suspension through its paces.
Pleased to report it works a great!
The hydraulic bump stops in particular are great at stopping extreme body roll!
Post #752608 20th Jan 2019 4:35pm
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Tried to fir Some LED backlights to my Dash, Tried being the operative word.
The T5s Went in Ok, with exception to the rev counter which is too long to fit, I think it needs the same lighting connection as the fuel indicator and engine temperature gauges.
The 509Ts were a total disaster, i spend a good 45 minuted trying to fit the damn things and i managed to get only one in before it went dark, no problems i was going to do the next one Day after.
After fiddling for 40 minutes, I got the second one in. Only problem is it had the wrong polarity, no problems.
I pulled it out, or so i thought. Instead i pulled the first one and now couldn't get either one in. But its ok, because the connectors snapped...
Go to put the old ones in...
Don't work...
Whoever designed the defender VDO speedo must have been an evil genius. and whoever assembled them must be doing penance for something. I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #752632 20th Jan 2019 5:56pm
rockster57
Snow is forecast hereabouts this week. Bring it on. I fitted my winter tyres today.
Having been following the current thread about half shafts, whilst the wheels were off I checked for wear at the flanges. Sure enough, looks like I have found another job to add to my list. In line with what others are experiencing, the o/s wear is more prominent.
Post #752661 20th Jan 2019 7:47pm
AlpinistG
Had day on hill then sunset drive.. perfect
Post #752673 20th Jan 2019 8:23pm
AlpinistG
Post #752674 20th Jan 2019 8:23pm
Huttopia
I took the pick up shooting on Saturday and giggled as the assorted Discoveries and Range Rovers slithered all over the place on fat tyres. Standard Michelin Latitudes worked well. The Heritage also went for its third service for the princely sum of £155. Yesterday I took my son to play hockey at a tournament in Solihull, so the pick up trundled up the M5/M42. There is something quietly satisfying about using the same vehicle for chugging across muddy fields one day and pootling along the motorway the next. Good old 300tdi Thumbs Up
Post #752725 21st Jan 2019 8:51am
landy andy
I love it when these bigger, and better off road vehicles (according to Land Rover, and the owner) struggle and the “crappy” Defender just drives past Rolling with laughter Bow down Rolling with laughter Bow down
Post #752735 21st Jan 2019 9:32am
Slideywindows
Or on the shoot I go to: the "crappy" ancient Series IIA drives past. Laughing
Post #752747 21st Jan 2019 11:24am
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Theres some stunners here, really need to get out in my defender more.... and not just daily for work... Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #752770 21st Jan 2019 12:46pm
Nigelpugh7
Another day out testing our new 12 inch travel suspension set up!
Post #752793 21st Jan 2019 4:34pm
Adam17
WOW!!! Regards
Adam
Loving The Duchess
Post #752797 21st Jan 2019 4:44pm
Nigelpugh7 wrote:
Is that a set up by King suspension by any chance? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #752812 21st Jan 2019 5:44pm
