![]() | Home > Technical > 200tdi white smoke and cuts out when revving |
| oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741
Did it have either of these problems before you changed the pump?
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
is engine running ruff
| dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668
I am reasonably confident that it is air in the system, I have ordered a replacement lift pump with new fittings. The fuel supply to the pump has not sealed and I think air is being sucked in to the fuel system. Will keep you posted. Won't be able to fit until Sunday earliest. 1990 200tdi conversion 90
| Bongo1 Member Since: 02 Nov 2018 Location: Cheshire Posts: 815
Did you ever sort this , Only a mates did the same thing today .
Sorry for late reply (been away) yes got it sorted, was the timing belt. 1990 200tdi conversion 90
