Home > Technical > MOT and emissions
Page 2 of 2 <12
Caterham
so it would appear my emissions would easily pass the 2014 requirements let alone the two preceeding requirements Cool
Thumbs Up Mr. Green
would be interested to know what emissions are typical for 2.2 and pretty good in so much that if I'm not mistaken my 2.4 is the same as a 2007 2.4 so pretty damn good huh?
Post #748505 1st Jan 2019 5:03pm
Caterham
Just a thought on this and it only really relates to tdci models. I've not heard of anyone failing the emissions test - has anyone and what was the issue?
I presume none have been the result of a re-map?
Just curious if failing on emissions is something of a time gone-by ie mech pumps and carbs?
Post #751517 15th Jan 2019 8:48pm
Bongo1
Caterham wrote:
/\ Very Happy
so went back to the MOT centre and asked for a print out of the emissions for interest and for your info should you wish to make comparisons.
I'd certainly be interested to know how it compares to others (but only if yours is higher / worse Mr. Green )
0.37 PPM which I believe is circa 25% of the max permissible of 1.5 PPM (?)
actually this is whats on the cert.
Test limit 1.50 l/m
absorption coefficient 0.38 l/m 2570 l/min zero drift 0.01 l/m
absorption coefficient after correction 0.37 l/m
Thumbs Up
Only got my defender 300tdi in OCT , But on the last MOT 17-2-18 Diesel Tune Analysis . Says smoke test , smoke reading reading 0.76 m1 max 1.50 , zero drift 0.02 0.10 max .
Goes in on thursday so will compare what that says , But no very good at 50% if yours is 25%
Post #751578 15th Jan 2019 11:45pm
Caterham
I'd have thought that was pretty ok (but then what do I know). I'd have expected a tdci to be significantly better than a td5 and a td5 better than a tdi.
I my understanding is the evolution of these engines is largely driven to emissions. Thumbs Up
Post #751609 16th Jan 2019 8:45am
yostumpy
That 1.5 is the fast pass limit, i.e. If it gets under that first go, then it'll pass. If it's above, then you have two more goes, and the average for the three, has to be below 3.0. ( because it's a turbo). ? Don't ask me why. 'Volvo XC 70, taking the rough with the smooth’
Post #751616 16th Jan 2019 9:11am
Retroanaconda
Failing emissions is down to either poor maintenance or a fault somewhere, not age or engine type.
Even my ancient Tdi with 346k on the clock passes first time, and has done every year for the ten MOTs I’ve put on it.
Post #751628 16th Jan 2019 10:03am
smb
^^^or maybe quality of fuel?
Last year reading at MOT time was 0.1. This time 0.51. However, this time I had just run through last ¾ tank of Diesel from Asda. Ran the tank to almost empty and filled up with BP Ultimate and after roughly ¾ tank went back to test emissions and it read 0.18. Maybe just coincidence, but I know next time hat I will be running before MOT.
That is with 170k on a 2.4tdci running a BAS remap with no egr, no cat and no middle silencer.
Post #751663 16th Jan 2019 12:36pm
smb
Last year reading at MOT time was 0.1. This time 0.51. However, this time I had just run through last ¾ tank of Diesel from Asda. Ran the tank to almost empty and filled up with BP Ultimate and after roughly ¾ tank went back to test emissions and it read 0.18. Maybe just coincidence, but I know next time what I will be running before MOT.
Post #751664 16th Jan 2019 12:37pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
It makes you wonder how strict they are, seems to a lot of stinking/smoking vans and diesel cars on the road that are within 10 years old....
Post #751686 16th Jan 2019 1:49pm
Bongo1
Bongo1 wrote:
Caterham wrote:
/\ Very Happy
Test limit 1.50 l/m
Thumbs Up
Only got my defender 300tdi in OCT , But on the last MOT 17-2-18 Diesel Tune Analysis . Says smoke test , smoke reading 0.76 m1 max 1.50 , zero drift 0.02 0.10 max .
Well MOT pass today . Emissions were better than the last MOT as seen above . 0.47 and zero drift 0.00 .
Post #752032 18th Jan 2019 12:30am
Bongo1
John64 wrote:
There is a huge difference in emissions limits pre June 2008 and after June 2008.
Is this current , mines a 1996 so it would be 3.0 , yet on the MOT it says 1.5 as the limit .
Post #752033 18th Jan 2019 12:42am
Mo Murphy
My smoke test this week on my 200 Tdi yielded a score of 0.14. I'm quite happy with that.
50 Shades of Pennine Grey
Post #752099 18th Jan 2019 1:29pm
Page 2 of 2 <12
