Home > Td5 > Wiring into a dummy switch
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Whilst furtling behind the console of my 2002 Td5 DCPU at the weekend I found this plugged into the back of a dummy switch amongst the 6 above the radio. If the switches were numbered 1-6 from left to right this was in #2. Based on the wire colour does anyone know here what this plug is/was for? Would it be for the rear window heater if this was a station wagon?
Post #751236 14th Jan 2019 6:44pm
rallysteve
Heated rear window from memory.
Post #751246 14th Jan 2019 7:07pm
rallysteve
Which usefully is wired all the way to the rear with a relay and fuse. Ideal for rear worklight or similar on a dcpu! 02' 110 TD5 Double Cab Rebuild Thread
Post #751247 14th Jan 2019 7:08pm
landy andy
Yes I think it is. Wrong slot on the dash though.
Does this help.
Post #751252 14th Jan 2019 7:14pm
hank
Exactly! See the following thread for the proper connector https://www.defender2.net/forum/topic65364.html to make up a patch lead!
Only slight annoying thing is that the heated rear screen dash light will illuminate when in use
I have done similar for my winch isolator using the rear wash wipe connector, see here https://www.defender2.net/forum/topic63641.html
You will need a rear heated screen switch, and if you want to be extra posh you can change the front for a work light switch front like this one https://rover.ebay.com/rover/0/0/0?mpre=ht...3085133241 > 110 XS Double Cab
Post #751258 14th Jan 2019 7:29pm
rallysteve
Easy enough to disable the HRW telltale in the binnacle though.
Post #751275 14th Jan 2019 8:24pm
Intercept
Excellent - thanks everyone. An interior light above the rear tub and a worklight outside are now on the jobs list Smile
Post #751327 14th Jan 2019 11:19pm
hank
Steve
Would appreciate if you can explain how? > 110 XS Double Cab
Post #754718 29th Jan 2019 11:07am
Martin
Site Admin
Remove the pin from the instrument cluster connector would be my preferred way.
White with Black to pin 19.
Take care as there are a number of similar coloured wires in there.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #754740 29th Jan 2019 12:42pm
hank
Thank you Thumbs Up
Are there any specific pin removal tools required?
Same for the switch connectors below how are the pins removed?
 > 110 XS Double Cab
Post #754747 29th Jan 2019 1:13pm
Intercept
On some versions there is a flip-over bar which clamps onto all the wires - if present this needs to be flipped up. Then each of the contacts is held into the housing by a barb which can be released by pushing a fine jewelers' screwdriver into the gap above the contact metal i.e. don't poke the screwdriver down the pin hole. On Molex connectors you can access each barb from the side without any poke & hope, but these seem to be less friendly.
Post #755018 30th Jan 2019 6:37pm
PaulMc
To release the terminals from a switch connector
Use a small screwdriver to open the hinged terminal lock, 1st side -
And the 2nd side -
Hinged terminal lock opened -
Use a safety pin to lift the locking tab above the terminal -
At the same time as lifting the locking tab, pull GENTLY on the terminal's wire -
Terminal released from connector housing -
Repeat for the other three terminals -
With the terminals removed from connector housing, you can now easily see the terminal locking tabs above each terminal’s cavity -
This animated cross-section shows what you are trying to do -
. Paul.
Post #755104 30th Jan 2019 9:45pm
It doesn't get any clearer or easier to follow than that, thanks Paul! Thumbs Up
Post #755130 30th Jan 2019 11:28pm
hank
My god. The man is extraordinary > 110 XS Double Cab
Post #755161 31st Jan 2019 5:22am
