Home > Td5 > Wiring into a dummy switch |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
Heated rear window from memory.
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
14th Jan 2019 7:07pm |
Which usefully is wired all the way to the rear with a relay and fuse. Ideal for rear worklight or similar on a dcpu! 02' 110 TD5 Double Cab Rebuild Thread
14th Jan 2019 7:08pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5422 |
Yes I think it is. Wrong slot on the dash though.
Does this help. Click image to enlarge |
14th Jan 2019 7:14pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2231 |
Exactly! See the following thread for the proper connector https://www.defender2.net/forum/topic65364.html to make up a patch lead!
Only slight annoying thing is that the heated rear screen dash light will illuminate when in use I have done similar for my winch isolator using the rear wash wipe connector, see here https://www.defender2.net/forum/topic63641.html You will need a rear heated screen switch, and if you want to be extra posh you can change the front for a work light switch front like this one https://rover.ebay.com/rover/0/0/0?mpre=ht...3085133241 > 110 XS Double Cab > Instagram @simonlanemind |
14th Jan 2019 7:29pm |
Easy enough to disable the HRW telltale in the binnacle though.
14th Jan 2019 8:24pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
Excellent - thanks everyone. An interior light above the rear tub and a worklight outside are now on the jobs list
14th Jan 2019 11:19pm |
Would appreciate if you can explain how? > 110 XS Double Cab > Instagram @simonlanemind |
29th Jan 2019 11:07am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6481 |
Remove the pin from the instrument cluster connector would be my preferred way.
White with Black to pin 19. Take care as there are a number of similar coloured wires in there. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
29th Jan 2019 12:42pm |
Thank you
Are there any specific pin removal tools required? Same for the switch connectors below how are the pins removed? > 110 XS Double Cab > Instagram @simonlanemind |
29th Jan 2019 1:13pm |
On some versions there is a flip-over bar which clamps onto all the wires - if present this needs to be flipped up. Then each of the contacts is held into the housing by a barb which can be released by pushing a fine jewelers' screwdriver into the gap above the contact metal i.e. don't poke the screwdriver down the pin hole. On Molex connectors you can access each barb from the side without any poke & hope, but these seem to be less friendly. |
30th Jan 2019 6:37pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 487 |
To release the terminals from a switch connector Use a small screwdriver to open the hinged terminal lock, 1st side - Click image to enlarge And the 2nd side - Click image to enlarge Hinged terminal lock opened - Click image to enlarge Use a safety pin to lift the locking tab above the terminal - Click image to enlarge At the same time as lifting the locking tab, pull GENTLY on the terminal's wire - Click image to enlarge Terminal released from connector housing - Click image to enlarge Repeat for the other three terminals - Click image to enlarge With the terminals removed from connector housing, you can now easily see the terminal locking tabs above each terminal’s cavity - Click image to enlarge This animated cross-section shows what you are trying to do - . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
30th Jan 2019 9:45pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16879 |
It doesn't get any clearer or easier to follow than that, thanks Paul!
30th Jan 2019 11:28pm |
My god. The man is extraordinary > 110 XS Double Cab
31st Jan 2019 5:22am |
