Home > Maintenance & Modifications > Snapped rear one piece half shaft.
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Ooops had a bit of a whoops moment greenlaning at the weekend. Thankfully the shaft snapped at the hub end so no need to pull the diff etc. Its a 2003 td5, I've been told to put a puma shaft in it as its stronger. Made it a interesting day as I was the 1st of 4 landrovers and had to winch up the rest of the lane. Thankfully their was plenty of trees! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #748291 31st Dec 2018 5:44pm
Co1
Blimey! I know people say it is a risk going one piece, but I didn’t believe it until now!
Post #748299 31st Dec 2018 6:10pm
jst
Tc or a locker fitted? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #748301 31st Dec 2018 6:21pm
gazman
Neither. 33" tyres that slipped on a rock and bounced. I think the spin and then the sudden grip caused it to go 2014 - current ..... 2003 defender td5 90 (my car)
Post #748320 31st Dec 2018 7:17pm
jst
Unlucky, but the 33s put quite a large turning moment on the shaft compared to std, one of the risks of uprising I guess. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #748328 31st Dec 2018 7:56pm
Mo Murphy
I've never heard going one-piece half shaft described as a risk 😂
On the other hand a big spinning wheel that stops suddenly will always shock something, usually the half shaft.
If you've never broken a half-shaft you haven't been trying hard enough 😉👍
50 Shades of Pennine Grey
Post #748336 31st Dec 2018 8:20pm
Jontd5
Ireland
Was out yesterday with D2 and had a similar / worse experience - fun decent from hills and drive home😎
Post #748340 31st Dec 2018 8:29pm
miker
Ahh, the rare "transparent diff cover" upgrade
Post #748346 31st Dec 2018 9:01pm
Care to explain this odd sentiment? Why is one-piece riskier that two-piece? When it breaks it is just as broken!
That's a very popular and common method to break halfshafts!
Post #748387 31st Dec 2018 11:45pm
Oldowner
It’s said to be a risk as the late td5/ Puma shaft is constant diameter all the way down the shaft, whereas the 300tdi shafts are waisted. I’d still rather the 300tdi shafts and zero backlash/ stripped rear drive members though.
Post #748421 1st Jan 2019 8:32am
Co1
[quote="blackwolf"]
The two piece shafts wear at the drive member splines and are pretty simple to fix. If the single piece shaft snaps it can mean splitting the diff from the axle to get it out if Lady Luck isn’t on your side.
Post #748435 1st Jan 2019 10:35am
Mo Murphy
Er, you can still snap a 2 piece half shaft !
Post #748443 1st Jan 2019 11:54am
Co1
Yes, of course it is possible. However The vast majority of issues with the two piece shaft is people reporting spline wear on/at the drive member, not the shaft snapping.
Have a search on the forum for one piece half shafts and read up on the general consensus. From my perspective, the jury is out and I still consider fitting the one piece units the next time the drive member splines are worn. This is the first time I’ve actually seen one snap, hence the surprise.
Happy new year to you.
Post #748444 1st Jan 2019 12:01pm
A broken one-piece shaft is no harder and no easier to remove than a broken two-piece!
Post #748459 1st Jan 2019 2:05pm
Mo Murphy
Co1,
Forgive me but you cannot compare wear in one with shock induced breakage in another Shocked
2 piece irritatingly wear at the drive flange splines, single piece do not.
Both types will snap if overloaded. 10 spline will break more easily than 24 spline.
Quite often if the shaft breaks at the diff, the broken stub can be removed without diff removal with the use of an appropriate magnetic removal tool such as that produced by X-Eng, dependant of course on the amount of twist prior to breakage and spline condition.
I have plenty of my own practical experience of shaft breakage over the years and really don't feel the need to explore the consensus of other armchair experts Wink
I take a one piece half shaft over a two piece any day.
HTH
Post #748489 1st Jan 2019 4:16pm
