Home > Td5 > Defender TD5 Clock
Page 2 of 2 <12
rallysteve
I am sure there is a recess in the plastic bezel that you can pry it off with. Be aware that the plastic pushrods that do the adjustment are only held in by the bezel and easily drop out when dismantling. 02' 110 TD5 Double Cab Rebuild Thread
Post #747573 27th Dec 2018 5:11pm
PaulMc
Thanks Steve Thumbs Up Paul.
Post #747612 27th Dec 2018 7:38pm
lightning
That’s great, can’t believe l paid £260 for a genuine unit!!
Shows how much profit someone is making at that price.
The LR genuine part used to be around £85 but some years ago they biffed up all the parts prices. A TD5 CAT downpipe is £900 lol l bet they shift loads of those....
And plastic trim parts are extortionate, for instance the plastic “A” pillar trim is £85 and is of such poor quality it would be expensive at £10.
Post #747654 27th Dec 2018 10:10pm
Jontd5
Ireland
lightning wrote:
Hmmm..... listing doesn’t inspire confidence
Has anybody actually fitted one?
Yeah I fitted that cheap clock - the main reason I picked that one was it was cheap if my attempt to feed it from alternator didn't work and also it was reasonably close in looks to the factory clocks.
It works no problems at all, fitting wire to alternator is a bit awkward but worth it
Post #747675 28th Dec 2018 8:39am
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
How long have you had it in there now? Is it holding up?? Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #747708 28th Dec 2018 1:02pm
Jontd5
Ireland
About 3/4 weeks and all perfect
Post #747709 28th Dec 2018 1:23pm
Adam17
Great! Regards
Adam
Loving The Duchess
Post #747737 28th Dec 2018 3:23pm
izack98
Canada 2001 Defender 110 2.5 TD CSW Chawton White
Just reviving this old thread as I have just replaced my dash lights with LED.
I was able to get the clock apart, clean it and get it working. I found that when reinserting it, if I tightened the ring that holds it in too tight it would stop working. I tightened it just enough to hold it and it works fine.
rallysteve are you able to post a link or a part # for the LED lights that you used inside the clock? I'd like to pick some up and swap out the ones that are in there.
Post #877373 10th Jan 2021 12:35am
Page 2 of 2 <12
