Home > Td5 > TD5 Starting Issues
mpald
United Kingdom 2004 Defender 90 Td5 HT Keswick Green
TD5 Starting Issues
Would be grateful for any pointers as to what my problem could be.
On my 2004 TD5, I have just started having some issues on starting up. so far, once on every 10 or so occasions, the vehicle does not start on ignition; electrics are working and dashboard lights are on at position 2, but as the key goes to position 3, it fails to fire up - it does not turn over but just makes a soft clicking sound.
Is this likely to be an earthing fault, glow plugs, or the ignition?
Any suggestions much appreciated.
Post #747412 26th Dec 2018 6:17pm
kyvlle
United Kingdom 2004 Defender 110 Td5 XS CSW Epsom Green
I'm having the same issues too! Also an 2004 TD5. Rang my mechanic before Christmas, and it sounds like the starter motor solenoid is going bad. Booking it in to get it fixed early in the New Year.
Post #747419 26th Dec 2018 6:56pm
grafty99
Sounds like starter solenoid to me. If the battery is in good health and all of the connections and ground points are good then that is the most likely cause. It's a common failure point.
Solenoid rebuild kits are inexpensive Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #747423 26th Dec 2018 7:19pm
dorsetsmith
TD5 starter motor see link below very useful
https://www.defender2.net/forum/post563456.html#563456
Post #747429 26th Dec 2018 7:54pm
mpald
Thank you all - much appreciated. I'll get on to it in the morning.
With thanks.
Post #747447 26th Dec 2018 9:05pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Was it damp when you had the issue??
Before you swap out the starter or RIP anything to bits, try and wiggle the wires on the starter motor. I had a issue with mine and it was intermittent but would leave me stranded.
I was told during one event to try and move the starter wires. Low and behold it worked.
When I got it home I disconnected the battery, cleaned all the contacts and added electrical grease and it's been spot on since. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #747488 27th Dec 2018 12:20am
mpald
Thanks for the suggestion; I am having a look this morning. It wasn't really damp; I garage it overnight and the problems have been on short trips rather than after a good soaking or taking it through thick mud. it will be worth a try, though.
Post #747518 27th Dec 2018 11:36am
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Great info here guys, cheers.
I also own a 2004 TD5 - ill keep this info in mind - I have seen the starter repaired - and doesn't look too difficult... Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #747532 27th Dec 2018 12:31pm
