![]() | Home > Td5 > TD5 Starting Issues |
kyvlle Member Since: 22 Jul 2016 Location: Essex Posts: 76 ![]() ![]() ![]() |
I'm having the same issues too! Also an 2004 TD5. Rang my mechanic before Christmas, and it sounds like the starter motor solenoid is going bad. Booking it in to get it fixed early in the New Year.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Sounds like starter solenoid to me. If the battery is in good health and all of the connections and ground points are good then that is the most likely cause. It's a common failure point.
Solenoid rebuild kits are inexpensive ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
TD5 starter motor see link below very useful
https://www.defender2.net/forum/post563456.html#563456 |
mpald Member Since: 16 Dec 2016 Location: North East Posts: 50 ![]() ![]() ![]() |
Thank you all - much appreciated. I'll get on to it in the morning.
With thanks. |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
Was it damp when you had the issue??
Before you swap out the starter or RIP anything to bits, try and wiggle the wires on the starter motor. I had a issue with mine and it was intermittent but would leave me stranded. I was told during one event to try and move the starter wires. Low and behold it worked. When I got it home I disconnected the battery, cleaned all the contacts and added electrical grease and it's been spot on since. 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
Thanks for the suggestion; I am having a look this morning. It wasn't really damp; I garage it overnight and the problems have been on short trips rather than after a good soaking or taking it through thick mud. it will be worth a try, though.
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
Great info here guys, cheers.
I also own a 2004 TD5 - ill keep this info in mind - I have seen the starter repaired - and doesn't look too difficult... Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
