Home > Td5 > Td5 Centre Exhaust Box and Griffin exhaust
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
I am sure many of you will have removed your centre box does it create a drone at cruising speeds 60-65mph?
Does the griffin system create extra drone at cruising speeds?
Thanks 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #747443 26th Dec 2018 8:51pm
miker
I've got a cheap straight thru centre pipe on mine, and I think it drones a bit at motorway speeds, but to be honest not enough that it bothers me. I also can't remember what it sounded like before!
Post #747490 27th Dec 2018 1:45am
landy andy
I removed the centre box on my 110 and found no noise difference at all. This was different on my 90 where it was noticeable. And VERY noticeable with the cat removed.
Post #747496 27th Dec 2018 8:22am
lightning
Now here’s a thing.
I fitted an aftermarket decat pipe to my 2005 110 and the droning at motorway speeds was such that l ended up refitting the CAT. A year or so later l tried again, this time with a genuine Land Rover part (at £180, three times the price)
Result? No droning at all at motorway speeds. How can this be from just a piece of pipe with no silencer? I can only assume the LR one must be made from thicker metal or maybe acoustically tuned in some way.
TBH l can’t feel much difference with the decat pipe fitted, l was told that the turbo would “spool up faster” but it feels the same to me.
Post #747506 27th Dec 2018 10:45am
MJN110
thanks for your responses.
I was planning to leave the CAT installed.
Lightning are you saying you can buy a genuine land rover straight pipe to replace the centre silencer? 2016 Defender Landmark 90
Post #747587 27th Dec 2018 6:23pm
lightning
You can buy a genuine straight through front pipe as it was standard on pre-2002 Defenders.
Centre pipe delete was never standard so no, you’ll have to buy aftermarket.
Post #747589 27th Dec 2018 6:35pm
MJN110
Thanks i understand now but that would be a MOT fail on my 2005 2016 Defender Landmark 90
Post #747594 27th Dec 2018 6:46pm
miker
Worth noting that mine is pre-cat, so the only silencer in the system is the one by the rear wheel.
Post #747599 27th Dec 2018 6:52pm
