Home > Td5 > Reverse lights on as soon as ignition on.
AJC
My reverse lights are sticking on. As soon as ignition is on. They come on.
I have a switch that’s on permanent live that will turn reverse light and works lights on if ignition is on or not. This has been fine for 2 years.
With ignition off. If I press the switch to turn work lights and reverse light on I can hear fuel pump prime etc as if ignition is on.
This suggests to me a back feed to ignition or a wire broke to ignition live, any suggestions? Thanks
Post #747170 24th Dec 2018 2:18pm
dorsetsmith
Sound like it, big 4mm white wire feed from the ignition switch down to the fuse box under the dash
Post #747176 24th Dec 2018 2:51pm
Without knowing how you've wired it up, it's difficult to offer a detailed answer. It's sounds very much like an earth fault , though. I'd start by looking at the earth wiring for your additional switching. Darren
Post #747177 24th Dec 2018 2:52pm
Mo Murphy
I'm with Mr Anorak, sounds like an earth issue to me.
50 Shades of Pennine Grey
Post #747180 24th Dec 2018 3:24pm
AJC
Thanks guys. Done some more digging.
Swapped switches. Same problem.
Disconnect switch fully. Same problem.
So I’m currently at. Dicky wire or nackered reverse switch. Light still permanently on with ignition on.
Post #747192 24th Dec 2018 5:09pm
dorsetsmith
1. trailer lighting socket and wiring give it good check over
2. Wiring for Reverse lights switch run down side Gaer box has wiring rubbed on metal work short out Question
Post #747196 24th Dec 2018 5:42pm
Disconnect the reverse light switch on the gearbox and see what happens. If the switch has failed short circuit you will get exactly this effect.
Post #747218 24th Dec 2018 7:52pm
AJC
Dorset Smith. Blackwolf
Thank you, did cross my mind on both things. Will get on it this week.
Post #747248 24th Dec 2018 10:54pm
Rkcorry
Just recently I had an issue with dash and lights coming on when applying the brake pedal, When stationary it would appear as if the ignition is on.
After some consultation with an online search engine, it turned out to be a corroded connection in the rear osr stop light.
As the guys above more likely a troubled earth connection.
Post #747280 25th Dec 2018 11:39am
AJC
All lights are LED with new plugs etc. I’m hoping it’s not an earth issue with one of them.
To gain access to reverse switch, can anyone suggest best way to get to it. TD5 110. Thanks
Post #748100 30th Dec 2018 7:52pm
AJC
Fixed. Was reverse light switch
Post #748428 1st Jan 2019 9:55am
