![]() | Home > Td5 > Reverse lights on as soon as ignition on. |
Sound like it, big 4mm white wire feed from the ignition switch down to the fuse box under the dash
![]() Click image to enlarge ![]() Click image to enlarge Last edited by dorsetsmith on 24th Dec 2018 3:26pm. Edited 1 time in total |
Without knowing how you've wired it up, it's difficult to offer a detailed answer. It's sounds very much like an earth fault , though. I'd start by looking at the earth wiring for your additional switching. Darren
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2394 ![]() ![]() ![]() |
I'm with Mr Anorak, sounds like an earth issue to me.
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1371 ![]() ![]() |
Thanks guys. Done some more digging.
Swapped switches. Same problem. Disconnect switch fully. Same problem. So I’m currently at. Dicky wire or nackered reverse switch. Light still permanently on with ignition on. |
1. trailer lighting socket and wiring give it good check over
2. Wiring for Reverse lights switch run down side Gaer box has wiring rubbed on metal work short out ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17950 ![]() ![]() ![]() |
Disconnect the reverse light switch on the gearbox and see what happens. If the switch has failed short circuit you will get exactly this effect.
Dorset Smith. Blackwolf
Thank you, did cross my mind on both things. Will get on it this week. |
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 227 ![]() |
Just recently I had an issue with dash and lights coming on when applying the brake pedal, When stationary it would appear as if the ignition is on.
After some consultation with an online search engine, it turned out to be a corroded connection in the rear osr stop light. As the guys above more likely a troubled earth connection. |
All lights are LED with new plugs etc. I’m hoping it’s not an earth issue with one of them.
To gain access to reverse switch, can anyone suggest best way to get to it. TD5 110. Thanks |
Fixed. Was reverse light switch
