Home > My Defender > Grafty's Td5 90 |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7876 |
Great photos of the 3 together! James
16th Dec 2018 9:25am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
Thanks James 2002 90 Td5 Station Wagon
16th Dec 2018 7:31pm |
Today's modification is rubber spring isolators. It's a job I've been meaning to do for ages but never got round to it.
I bought the Disco 2 rubberised turret rings and the standard rubber rings for the rear. Fitted up with copious amounts of grease it took about 2 hours all in (including tea). I've been out for a quick spin and it seems to have made a tangible difference to the ride quality and has reduced some road noise I think (tyre noise is unchanged). I'm tempted to put isolators on the bottoms of the springs too but I'm not sure if that would be overkill/deminishing returns? I'll definitely be doing it on the Range Rover as well but not until it's in the workshop for the respray. Anyway it's done and I think has made a difference. I'd recommend it especially if you were in the spring/damper area doing something else 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
21st Dec 2018 8:48pm |
It's a great mod but I can't see the value in adding the isolators at the bottom, too. It can't be any more isolated. Darren
21st Dec 2018 9:17pm |
I suppose not, would it not help smooth out the ride just that little bit more? 2002 90 Td5 Station Wagon
21st Dec 2018 9:26pm |
I think you may be in Princess and the pea territory. Darren
21st Dec 2018 10:13pm |
You're probably right 2002 90 Td5 Station Wagon
21st Dec 2018 10:41pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4951 |
I might look into this too, my suspension dampers are crap. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
22nd Dec 2018 6:01pm |
RANGER1312 Member Since: 04 Feb 2018 Location: Fylde Coast Posts: 125 |
I noticed in the last pic you posted you've installed grab handles on the A pillars Grafty
This is something I've always wanted to do to mine but always thought there wasn't enough space to house them, are they LR ones and if so do you know the part number? Really love all your subtle touches |
1st Jan 2019 11:34pm |
Well spotted!
I've just fitted the one to the passenger side, but you could just as easily fit one to each side. It's the same standard plastic pull handle as on the door cards. The hole spacing is an exact match for the a pillar fixings, which is nice! I took a file to the back of the handles to profile the base of the handle to the same profile as the a pillar trim. As it matches the door handles it looks factory from the inside 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton Last edited by grafty99 on 26th Jan 2019 3:14pm. Edited 1 time in total |
2nd Jan 2019 10:21am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16939 |
I've done the same, and the handles are so useful that you wonder how you managed without them.
2nd Jan 2019 11:26am |
2nd Jan 2019 3:22pm |
They're a real neat touch!
So they just need filing down to fit flush? |
2nd Jan 2019 6:59pm |
Yeah just a bit of fettling with a half round file and some slightly longer screws and you're good to go 2002 90 Td5 Station Wagon
2nd Jan 2019 8:08pm |
