![]() | Home > Td5 > Defender MPG |
Norton Member Since: 10 Sep 2018 Location: Buckinghamshire Posts: 28 ![]() ![]() ![]() |
Around low 20's at motorway speeds. High 20's on A roads.
Having done several runs to and from pompy averageing 170ish miles each way I’m doing the trip in about a 1/3 of a tank so I must be close to 30 mpg in Buggsy, makes no real difference if loaded or not and the whacking great roof rack doesn’t seem to effect it, I normally sit around 55-60 and am driving in stupid o’clock hours. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
I put in £40 per week and do on average 800 miles a month, so £40 gets me 200 miles!!!!
Any good??? |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 ![]() ![]() |
I do mainly short trips and last time I calculated I was getting about 27mpg running STT pro tyres
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
Caterham has some high claims and I have tried to match them which I can for short periods of time, but it needs to be in the 1500-1750 RPM range and between 30 and 50mph, you will be surprised what can be achieved if you try to drive in this range.
Unfortunately I cant do it for long as I get fed up quickly. notably both myself and Caterham have 2011 2.4s DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
I think ill start a tally of what im spending and how many miles im getting - I do reset the counter each time I fill up. And usually get between 230-280 a tank.. Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6018 ![]() ![]() ![]() |
I get around 300 to a full tank in my 110 (but always find the needle for the fuel gauge drop quicker from half to 1/4 than full to half) 1999 Defender TD5 110
The needle doesn't seem to move from full till after the first 60 odd miles in mine.
Mine is the same but its half to 1/4 that drops really quick compared to the miles covered 1999 Defender TD5 110
Agreed - I fill right to the brim! and get nearly 60 miles from past the full mark to the full mark, but then between full and 1/4 its like 180 miles... Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
The fuel gauge on the Td5's are very non-linear, I might get 100 miles+ from the first quarter then only about 50 or less from the last. My previous one was just the same, not much more than a rough guide really, better than nothing though
![]() On a high note, I was away over the weekend and came back from Canterbury, plus a bit of running around and got 350 miles from a full tank (49.3 litres to the brim,) of Morrisons finest regular diesel, = 32.26 mpg ![]() |
I never let mine go past half way as I've run out before when guage was on the last quarter line.
Nice! That's good going that. I'm going to make a conscious effort to start recording my fuel stats. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3319 ![]() ![]() |
I have been firmly in the red at the bottom of the gauge and still running.
2005 TD5 110 But l normally fill up when it gets to half full, as it definitely rides a bit better with the extra weight. ![]() Click image to enlarge |
