![]() | Home > Maintenance & Modifications > The security question again |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
I have the pedal lock and removalable steering wheel with boss lock and I’m happy, quick to fit, offers some peace of mind without being a PIA to use and I drive mine everyday so need something functional without being awkward to fit, hope this helps
![]() 2008 SVX 90 2000 XS TD5 90 |
Dobby Member Since: 23 May 2012 Location: East Seaxe Posts: 187 ![]() |
Or.... just spend the money on a better insurance policy, with an agreed value. Rather than a bargain basement online policy that’ll shaft you in the event.
Much better for your blood pressure than having to constantly worry about all your security heels and whistles. There’s money in the fear that is peddled about car thievery. As the old adage goes, if they want it they’ll take it. |
I have a very good 'fleet' policy
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8350 ![]() ![]() ![]() |
X~eng ignition lock as another layer. Stops std steering lock being broken off. Cheers
Hydraulic lock system Cheers
What's one on those ? 130's have feeling's as well you know
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
I would say ditch the factory immobiliser and alarm system. They can’t defeat what they don’t expect.
Eventually going to get rid of the disklok for a optimil QD hub lock... seems like less hassle. Interested in those mech locks... anyone have one? I think this whole hiab stuff is misunderstood, I think it’s tow trucks with winches rather than rigids with cranes. So you should be able to defeat them by parking in gear... Also a good tracker is better than physical security. It will lower your premiums and the leading two products (tracker, Automatrics & defender defender) all have vibration monitors that text you when your vehicle has been moved. Last month I drove somewhere at 4am without disabling the system and got a call from my tracking company. “Hi, Mr Osloblue I’m calling from your tracking company, sorry to wake you, but we’re calling you to let you know your car has been stolen, but not to worry we’re tracking it and in the process of informing the police” the lady said smugly I had to inform her that I was still in possession of my car and driving it in fact... I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
https://www.landroverdefendersecurity.com/...-mechanism Not necessarily that one but you get the idea, brake or clutch system. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
I tried everything and I mean everything. All I found was they kept coming back and probing to see what security I had.
What stopped it literally over night was a 2nd alarm with a warn away sounder. I still have the normal landrover one, but it is modified. It wouldnt work if you had to park over night on a road as it would chirp constantly, but it's that good my mate went out and got one on his too. I park mine on the drive and I've even forgotten on occasion to remove the steering wheel, pedal lock and even lock it but it's been left alone! I have trackers too that alarm with the alarm and start signalling me. I really dont worry about it anymore.wouldnt leave it anywhere dodgy though 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
Defenders locked up out of sight in a monitored alarm building is probably one of the best preventive measures. Not always possible.
Many of the possible measures have already been mentioned. Now some thieves overcome alarm etc and then push vehicle onto road etc. If wheels are in a trough then it will be difficult to push the vehicle away. A big chain from recovery point to a solid ground anchor? A monitored alarm on the drive or yard? No good if postman etc walks up drive. Brendan |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1451 ![]() ![]() ![]() |
Unfortunately prevention is always behind and out dated, and new options are good until defeated......which they invariably are
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
If it's one of the later Pumas this won't fit, only works up to MY 2014 |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello AndrewS
If I were forced to have just one security measure then this would be it...Nothing is 100% but armed with several additional layers, this IMO is a very good measure...(I really don't understand why it isn't used more often). Negatives... Not many IMO, you either have to get back to the Spline and a good Boss Lock and Security Fixings (or in my case something custom) can make this time consuming, and then carry a spare Steering Wheel (of the correct type) to get you past this measure. Or some systems can be jammed with a screw driver or gripped with a G Clamp to gain enough purchase to steer away, but there are ways to minimise this 'failing'. For Vehicles parked in the same place then coming prepared can be planned for but for random parking and being confronted with this for the first time, it's a strong physical and visual message. ![]() Click image to enlarge
I agree...last resort, but have one (or two) Also... X Defend https://foundry4x4.co.uk/pdf/X%20Eng%20at%...ctions.pdf Security Marking http://www.retainagroup.com/ BBS I have a few of these fitted, both externally and internally. Not the standard LR BBS (Battery Back Up Siren) but an alternative. When triggered it is difficult to stay in the Vehicle ![]() Good Luck. SKIP https://www.defender2.net/forum/topic83242.html |
Fairy nuff. ![]() In that case.. if you can/want--do some or all of these things depending on how much you want to spend.. But you're right a battery cutter/whizzer is your main enemy. 1. Keep it in a garage when not in use. 2. Aim for the holy-trinity of add-ons. i.e. Pedal lock, Steering lock, gear lock. 3. Put Liquid metal in all your door fixings to stop door removal. You can buy posh hinges too, but LM is just as good. 4. Bike cable and padlock the bonnet to the engine. Posh hinges also available if you want. Be careful not to get the padlock in such a position that it sits on the top of the engine, otherwise you'll dent your bonnet when you close it. 5. Battery loom bypass. One of the main weaknesses is the battery loom being accessible underneath the vehicle, so can be easily cut to disable the alarm/locks. The bypass re-routes the power inside the cab instead. Leave original, but dead, loom in place. 6. BBUS for the alarm and relocate it away from the behind the headlamp location. And/Or drill out/liquid metal all the headlamp fixing screw heads. 7. Pedal locks, generally good but be aware of the weaknesses. Get one that covers the pedal arms too, otherwise they cut the arms and drive on the stumps. Make sure it covers all the pedals too, not just the brake. 8. Steering locks good. If you go for disklok get it modified to ensure it can't be 'peeled' off. Don't get one that can be removed by simply cutting through the steering wheel. Leave parked on full-lock 9. Steering locks #2. If you can/want weld on your drop-arm bolts. Steering locks are easily defeated by removing the bolt on the steering linkages so the vehicle can be towed away. 10. Block it in when parked. Towing is your greatest risk. A cheapo solid draw/tow bar is the normal MO. They'll even drag them if needed. Lifting also a risk, but minimal IMHO. 11. Tracker. Either go the full monty and get a posh one, or do the diy iphone 'find friends' version. Cheapo Chinese trackers also work well. The issue with the radio/UHF/VHF trackers is they are often put in a handful of places, and there are tell-tale signs that give them away. Blocking of all trackers also a problem, with cheapo jammers available on ebay. So be aware of that risk. 12. If a 110, cut off the rear door lock latch knob. The small knob on the lock, so the door can't be unlocked from the inside if someone pops in the small rear windows. 13. Those small rear windows on a 110 are a risk. Be aware they can be popped out easily, but various fixes are available. 14. Protect the bonnet pull cable with a guard above the rad, and liquid metal or rivet down the screws on the wing top blanking plate on the drivers side to protect the cable under there too. 15. Bike lock cable and padlock your spare wheel to the carrier on the rear door. 16. Security mark everything, windows, panels, wheels, seats. the lot. Use VIN or VRM as an etch. Lastly. Be aware that ALL of the solutions available have a work-around or weakness when used in isolation and the villains know them too. Don't fall for the vendors marketing guff, understand the workaround and seek to mitigate it. Add 2 or 3 different solutions if you can, but don't make your life hell when you come to use the vehicle or you'll end up not doing them at all and it's all for nowt. Also.. understand your local risk. Do you live in a high risk area like Yorkshire, or somewhere more sedate. Ask the local plod about vehicle/rural crime to get some idea of what the risk is and how vehicles are stolen. Likely to be crime gangs using the same methods each time. |
