Home > Maintenance & Modifications > TD5 rev counter - the cheap option
Page 1 of 4 1234>
Jontd5
Ireland
Was looking to get a rev counter for my 110, bought a cheap universal diesel on on eBay for 20 quid and added a W terminal to back of alternator. Didn't even have to take alternator off, was able to take back cover plate off from underneath
Post #746137 17th Dec 2018 4:30pm
miker
Very interesting! I've always been under the impression that even adding a W terminal wouldn't work due to the 5 cylinder vs 4 cylinder thing. Have you "calibrated" it against a nanocom or similar?
Any details on the mod to add the terminal?
Post #746161 17th Dec 2018 6:42pm
Jontd5
Ireland
Yeah wasn't sure it would work either - but set it up with nanocom at idle and at 1000, 2000, 3000 and 4000 rpm it was reading accurate. I bought the cheapest gauge I found for a diesel on eBay , partly because I wasn't sure it would work and partly it was reasonably simple in looks. It has no jumpers on the rear just a calibration screw. All I did with alternator was disconnect wire and remove the rear cover - managed to do it with alternator still in place, there a series of screws holding the rectifier plate onto alternator when you remove back cover one of these screws will be facing straight down towards the floor, i just attached a cable to that and ran it up to back of instruments, connected it up and all done.
It is a fiddle getting rear cover off but better than pulling alternator out. I will upload a photo of where to attach wire if that helps
Post #746163 17th Dec 2018 6:55pm
nice job. Yes some pictures would be good.
Post #746165 17th Dec 2018 7:04pm
rallysteve
Doesnt matter how many cylinders the engine has, the alternator still spins at the same speed. The only variable is the ratio of the crank and alternator pulley size 02' 110 TD5 Double Cab Rebuild Thread
Post #746166 17th Dec 2018 7:04pm
Jontd5
Ireland
These are photos from my spare alternator. I took off the rear cover and fitted a wire to the screw coming off the end of the stator
Post #746171 17th Dec 2018 7:15pm
bankz5152
Fantastic news! No more £200 rev counters!
Post #746174 17th Dec 2018 7:22pm
Jontd5
Ireland
eBay Item No. 362310571942
That's the gauge I used
Post #746175 17th Dec 2018 7:31pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Well done that man!!!! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #746260 18th Dec 2018 8:23am
excossack
What make of alternator is it? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #746277 18th Dec 2018 11:49am
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
I love doing mods on my TD5 defender I have ordered the same rev counter and looking forward to fitting it.
Thanks for posting this info. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #746285 18th Dec 2018 12:54pm
hank
That rev counter looks right at home in there Thumbs Up
Post #746286 18th Dec 2018 1:02pm
Jontd5
Ireland
Standard Td5 alternator - denso I think
Post #746299 18th Dec 2018 2:49pm
Jontd5
Ireland
https://photos.app.goo.gl/tPbTg3LXnboK8Fof7
Hopefully that video link will work
Post #746300 18th Dec 2018 2:50pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Looking forward to seeing the pics - may have to give this a go myself Wink
That video is great. matches up perfect. Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #747567 27th Dec 2018 4:55pm
Page 1 of 4 1234>
