Home > Puma (Tdci) > Diesel leak n/s of engine
Page 2 of 2 <12
If the VCV gasket (or that area.) was leaking it'd be likely be the lower side that's out of sight.
I had this situation with my waterpump a few years ago, couldn't see anything from above nor really from underneath until tracing it back from underneath and with really good light.
I'd clean it up, then take a look at where it originates from you should be able to trace it back but probably not from the top at all.
As those items (PRV and VCV) were recently changed I'd be thinking along those lines to be looking at especially the VCV as the PRV being much higher up should be easier to spot. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #746045 16th Dec 2018 6:31pm
Phid
Thanks for all of your help.
It is leaking from the fuel temperature sender.
I’ve tried to tighten it but it is right so assume I need to replace the unit or just the washer.
Can you buy the washer on it’s own?
Is it likely that this leak is causing a pressure drop and stopping the engine starting?
If I replace the sender with the fuel system need bleeding?
Thanks again
Post #746050 16th Dec 2018 7:21pm
Phid
Had another looks and tried to tighten the two Alan bolts next to the VCV. They were not nipped up. I have tightened them a bit and retried to start. No leak. It must have been running down onto the fuel temp sender. I need to try and tighten more (longer Alan keys?).
However still not starting - could that be air in the system or still need to tighten the bolts?
How do you bleed if air in?
Post #746055 16th Dec 2018 8:06pm
dorsetsmith
Post #746060 16th Dec 2018 8:18pm
Phid
8nm - that’s not very tight. No surprise they came loose. It’s good they don’t have to be too tight as they’re a pig to access.
That bleeding doesn’t look straight forward unfortunately 😬
Post #746066 16th Dec 2018 9:34pm
dorsetsmith
Fuel System - General Information - Low-Pressure Fuel
System Bleeding from work shop manuel
link below
https://1drv.ms/b/s!AtZSoWFHDgnGkW4lPCyeH9UgniUW
Post #746072 16th Dec 2018 9:54pm
Phid
That looks easier - just need the special tool.
Thanks for all the help
Post #746079 16th Dec 2018 10:46pm
Dorsetsmith - Thank you for that VCV screenshot also.
May prove useful to me shortly.
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #746084 16th Dec 2018 11:39pm
Phid
Got it started however still leaking.
Is it possible to buy just a replacement gasket and o ring for the fuel vapour valve - ie not the whole unit? I’ve done a search but can’t find the separate parts.
Thanks
Post #748044 30th Dec 2018 3:22pm
dorsetsmith
hole thing only
VCV Kit part numbers
Landrover part LR009837
Ford part 1 514 885 (6C1Q 9358 AB)
or get sheet gasket paper make one and sort out Nitrile O-Rings
Post #748059 30th Dec 2018 4:36pm
Page 2 of 2 <12
