Home > My Defender > V8 90 Project
Page 12 of 14 <123 ... 11 121314>
Retroanaconda
If it’s sat on the standard LT85 mounts, which it looks to be, then there shouldn’t be any problem as it should all be in be normal V8 position.
Likewise unless you’ve changed the rear diff for something odd like a Salisbury or P38 short nose everything will be standard there too.
Post #729401 16th Sep 2018 10:09pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Hi Retroanaconda, yes the mounts are the same and it’s the original box etc, was just wanting to confirm as you do have some adjustments with the mounts having the elongated mounting holes to the chassis, don’t really want to tighten it all down and find I’m a few mm out on the engine install. The axles have been swapped for 110 Wolf axles which I believe is the same as a p38 diff, I will have to hunt for the rear prop and mount it to check alignment Thumbs Up
So next update:
With a rough date of needing it a moveable condition by May 19 I do really need to get a move on Shocked so last weekend was a day it started to take shape:
The old bulkhead is now fully stripped and the majority of metal parts have been cleaned and painted:
Out with the old in with the new:
You can make out the year of manufacture is 1987 so both wheel boxes were original fitment, shame to change them but the are rough and notchy.
Favourite tool this week has to go to the sand blaster for turning bits like this:
Into this:
Hopefully some good updates to come over the next week or so once my gaskets etc arrive Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #730966 24th Sep 2018 9:16pm
L110CDL
Nice to be moving forward a bit more now mash, the sand blaster is a great bit of kit to have, makes light work of all the rubbish on the items Wink Clayton.
Keeper.
Post #730983 24th Sep 2018 9:42pm
Procta
looking more like a car that now mash! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #731018 25th Sep 2018 6:06am
Mash
Cheers guys Thumbs Up is looking more 90ish but so much more to try and do Shocked
Well I have been able to do a few more bits on Maggie, it’s now at the stage of, clean paint and await of gaskets to fit, and then find bis you forgot to do so do them as well.
There are times when you look at something and ask yourself what have you done :
This is the point you walk away have a cuppa then come back to find it’s really easy Very Happy
And you end up with this:
So she is getting there............ slowly Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #731903 29th Sep 2018 8:41pm
L110CDL
I to find it's best to go and have a cuppa and then come back to it, it really does make a difference Thumbs Up
Nice bit of progress there Mash Very Happy Clayton.
Keeper.
Post #732296 1st Oct 2018 8:56pm
Mash
Totally agree Clayton Thumbs Up
Well it’s been a busy old week with some right Censored jobs, nothing’s been simple and easy, oh well now it’s the weekend and I have time for Maggie Very Happy
So today was a few quick jobs, using up my little delivery of L/R gaskets and seals surprising how quickly the total adds up in your basket Big Cry
So what I managed to achieve, steering box that has been overhauled (well cleaned and painted) as I snapped 3 sets of circlip pliers trying to replace the lower seal so I guess Maggie will be one to mark her territory Rolling with laughter fitted brake and clutch pedal boxes, fitted 4 out of 6 bolts to my throttle pedal as 2 holes don’t line up (a-?-e strike again Banging Head ) so not too bad for an hour or so tinkering, more to do tomorrow.
D3 Hse - Fiona
Capri 2l S - Anna
Post #735792 19th Oct 2018 9:04pm
L110CDL
Nice bit of tinkering there Wink Clayton.
Keeper.
Post #736251 22nd Oct 2018 9:21pm
Mash
Well I do apologise for my absence, life has been getting in the way of my Land Rover time, well rebuild time that is, I have clocked up close to 1000mi in just over a month in the 110 Shocked
So now I’m am back for a very short period and then off back to Guernsey for Xmas so this is the only update I have on Maggie Big Cry
So I have managed to find a few hours to tinker and have succeeded in producing a fully steering chassis Very Happy
I have also made a start on painting the wings, they have been primered and received their first top coat, not happy with the finish so wet and dry with another coat should give me the right finish.
D3 Hse - Fiona
Capri 2l S - Anna
Post #745905 15th Dec 2018 11:08pm
JOW240725
Amazing work, it's going to be awesome!! Looks like you're on the home run now Cool James
Instagram @suffolk_rovers
Post #745933 16th Dec 2018 9:35am
Mash
Cheers James Thumbs Up not on a home run yet though, still have the seat box back to strip and repair before paint, oh and the fuel system to fathom out as original pipes are shot and you can’t get them now, then there is brake lines, coolant pipe work etc Big Cry still it could be worse, I could have 3 defenders and a Disco to keep me busy Rolling with laughter 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #745957 16th Dec 2018 11:21am
JOW240725
Oh well, you know what they say about idle thumbs!! James
Post #745970 16th Dec 2018 12:25pm
Mash
Yep mine cost me a fortune on evilbay Rolling with laughter 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #746044 16th Dec 2018 6:07pm
Mash
More spraying today, got a few other bits done so slowly getting there with the painting Thumbs Up
Back off to Guernsey tomorrow so no more tinker time with Maggie for a few weeks. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #746366 18th Dec 2018 11:54pm
L110CDL
Certainly taking Maggie a bit more forward Thumbs Up Clayton.
Keeper.
Post #746826 21st Dec 2018 10:39pm
