Home > My Defender > My 1984 Ninety V8 Slate Grey
Page 3 of 12 <123 4 ... 101112>
JOW240725
Slideywindows wrote:
Is your speedo reading still accurate?
I only got one on and decided the studs were too shot to continue. However from the sounds of it they may be OK so will try again, then use the satnav to see how accurate it is. Hopefully more accurate than the fuel guage! Shocked Whistle James
Instagram @suffolk_rovers
Post #744884 9th Dec 2018 9:41pm
dorsetsmith
JOW240725 wrote:
Thanks. The tyres are Cooper ST Maxx 235/85R16. They are standard size but look huge next to the little 205's.
and your speedo will read low i.e speedo show 30 mph your road speed 35 mph if the speedo drive gear is yellow to match 205 tyres Question (205 80 16 to 235 85 16)
https://www.land-rover-blog.co.uk/how-to-r...and-rover/
looking great
Post #744886 9th Dec 2018 9:44pm
Retroanaconda
You should be alright on the front axle with the Wolf wheels, however if you still have the drum brakes on the rear then the studs will probably come up a bit short.
Post #744891 9th Dec 2018 10:01pm
JOW240725
Oh cock! It was a front I tried and thought studs were too short. It does have drum brakes I assume (1984) so might need further work Big Cry James
Post #744893 9th Dec 2018 10:05pm
Love 'em James.
I've got the military studs, cost a fortune. They will restrict you to steel wheels, (in case you want alloys in the future) as the alloy wheel nuts don't work with them
You'll need a deep 27mm socket.
Regardless of what people say, I did it for MY peace of mind. Last year a young girl got killed when a wheel flew off a Disco and hit her.
Over torqueing the wheel nuts may stretch the studs.... A common issue on drift cars with frequent wheel changes and pit muppets whacking them up tight... The studs snap with the wheel taking orbit QRZ M8VPF
Post #744895 9th Dec 2018 10:08pm
JOW240725
That's exactly what concerns me Greeni, not something I want to get wrong. The extended ones are 60mm long but looks like these are far too long. I think I saw some 45mm long, are these what you have? Do you have a link? Smile James
Post #744897 9th Dec 2018 10:19pm
Without going measure (it's peeing down and I'm in my Cookie Monster comfy pants), I'd say they're the longest.
I had them from LRS, Derrick QRZ M8VPF
Post #744900 9th Dec 2018 10:28pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
My Ninetys are on original spec 205's, as the little 2.25 petrol engines don't seem like larger diameter tyres, but your V8 should have no trouble pulling the larger diameter.
Mine is on 205’s with the original Rostyle wheels, trundles along nicely at 55/60 on the Motorway, a nice speed for this vehicle and quite relaxing.
Post #744909 9th Dec 2018 11:41pm
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
Was just about to reply that my 90 V8 factory was overgeared when fitting 235 85 x16s - but as it was an original V8 and had a 1.19 ratio transfer box - I imagine yours has a 1.4 and will be perfect.
Also re wolf wheels, the Heritage Edition didn't use the longer studs so I assumed that would be good enough for me. Still irritates me and my sense of what should look right usually is right though!
 JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #744912 9th Dec 2018 11:52pm
seriesonenut
Hi
That's pretty much how the nut/studs look like on my 110 and our works 130 (fitted new from the factory). 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
1990 Defender 200tdi CSW (sold)
1989 Land Rover Ninety (sold)
1998 Discovery 2 (sold)
1995 Discovery 1 (auto) (sold)
1990 Discovery 200tdi (sold)
1987 One Ten CSW turbo diesel (sold)
Post #744913 9th Dec 2018 11:57pm
williamthedog
Yep, nothing wrong with those wheel studs, thats how mine looked like from the factory too Thumbs Up
Post #744923 10th Dec 2018 6:41am
dorsetsmith
Post #744932 10th Dec 2018 9:28am
Retroanaconda
The green wheel above is correct, and how they came out of the factory. However the extra thickness of the drums on the rear can cause them to not reach that level of engagement.
Post #744941 10th Dec 2018 9:49am
There used to be an ARC rule about wheel studs, them as above with the line across the end were the solution to the old problem and were deemed acceptable.
The military version are overkill... QRZ M8VPF
Post #745025 10th Dec 2018 8:14pm
JOW240725
Widget wrote:
Just test fitting one wheel with finger tight nuts without torquing was getting nowhere near that much thread. OK they would probably pull in a little more done up tight. But I'd rather be safe than sorry so a set of extended studs are on order Very Happy James
Post #745157 11th Dec 2018 2:17pm
