![]() | Home > My Defender > My 1984 Ninety V8 Slate Grey |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7944 ![]() ![]() ![]() |
I only got one on and decided the studs were too shot to continue. However from the sounds of it they may be OK so will try again, then use the satnav to see how accurate it is. Hopefully more accurate than the fuel guage! ![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
and your speedo will read low i.e speedo show 30 mph your road speed 35 mph if the speedo drive gear is yellow to match 205 tyres ![]() https://www.land-rover-blog.co.uk/how-to-r...and-rover/ looking great |
Oh cock! It was a front I tried and thought studs were too short. It does have drum brakes I assume (1984) so might need further work
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Love 'em James.
I've got the military studs, cost a fortune. They will restrict you to steel wheels, (in case you want alloys in the future) as the alloy wheel nuts don't work with them You'll need a deep 27mm socket. Regardless of what people say, I did it for MY peace of mind. Last year a young girl got killed when a wheel flew off a Disco and hit her. Over torqueing the wheel nuts may stretch the studs.... A common issue on drift cars with frequent wheel changes and pit muppets whacking them up tight... The studs snap with the wheel taking orbit QRZ M8VPF |
That's exactly what concerns me Greeni, not something I want to get wrong. The extended ones are 60mm long but looks like these are far too long. I think I saw some 45mm long, are these what you have? Do you have a link?
Without going measure (it's peeing down and I'm in my Cookie Monster comfy pants), I'd say they're the longest.
I had them from LRS, Derrick QRZ M8VPF |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
Mine is on 205’s with the original Rostyle wheels, trundles along nicely at 55/60 on the Motorway, a nice speed for this vehicle and quite relaxing. |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 635 ![]() ![]() ![]() |
Was just about to reply that my 90 V8 factory was overgeared when fitting 235 85 x16s - but as it was an original V8 and had a 1.19 ratio transfer box - I imagine yours has a 1.4 and will be perfect.
Also re wolf wheels, the Heritage Edition didn't use the longer studs so I assumed that would be good enough for me. Still irritates me and my sense of what should look right usually is right though! ![]() Click image to enlarge JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1260 ![]() ![]() |
Hi
That's pretty much how the nut/studs look like on my 110 and our works 130 (fitted new from the factory). 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 1990 Defender 200tdi CSW (sold) 1989 Land Rover Ninety (sold) 1998 Discovery 2 (sold) 1995 Discovery 1 (auto) (sold) 1990 Discovery 200tdi (sold) 1987 One Ten CSW turbo diesel (sold) |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Yep, nothing wrong with those wheel studs, thats how mine looked like from the factory too
This is good read LR wheel re stud
https://forums.lr4x4.com/topic/34407-new-wheels-too-thick/ |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2784 ![]() ![]() |
The green wheel above is correct, and how they came out of the factory. However the extra thickness of the drums on the rear can cause them to not reach that level of engagement.
There used to be an ARC rule about wheel studs, them as above with the line across the end were the solution to the old problem and were deemed acceptable.
The military version are overkill... QRZ M8VPF |
Just test fitting one wheel with finger tight nuts without torquing was getting nowhere near that much thread. OK they would probably pull in a little more done up tight. But I'd rather be safe than sorry so a set of extended studs are on order ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
