![]() | Home > Puma (Tdci) > Instrument cluster removal |
WindyJ Member Since: 18 Oct 2018 Location: France Posts: 190 ![]() |
If fitting a new one yes, but not if fitting same cluster back in.
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 ![]() ![]() |
Thanks Windy - makes sense!
Was a bit worried as I'd read on a S.African or Australian forum, that the dealer needed to re-program following a remove and re-fit, but seemed a bit odd... |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
I've removed mine and refitted it without problems on more than one occasion.
Removed the cluster this evening, and was surprised that the immobiliser is actually not behind the instruments.... I'm assuming that I have to remove the whole dash
![]() Anyone know how to release the connector? It looks like the the black bit is a retaining clip that needs to be lifted, and pivots around the hinge line. Its quite stiff through and a bit nervous about forcing it... ![]() Click image to enlarge Last edited by redline on 9th Dec 2018 7:04pm. Edited 1 time in total |
Also, any idea where I can get replacement retainers for the instrument cluster fixing screws?
Looks like the black thing comes up as arrowed yes. Cant remember tbh other than it was stiff. As far as those little blue things go, i ended up cutting a slot in and then gluing in some large wall plugs. Worked a treat!
Thanks Windy - excellent idea with the wall plugs! May copy that
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
The 10AS is in behind the speaker drivers side.
Excellent - Many thanks McNick! Was fearing a dash removal job...
Not possible to order separately from LR. This blue clip has no LR part number. But you can order it from BMW as they use it in their Mini. Google BMW part number 07131472727. Sometimes you also find it on eBay. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Merci Eric! I won't ask how you know this from your lovely SVX...!
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6693 ![]() ![]() ![]() |
See this thread from the other day https://www.defender2.net/forum/topic64947.html ![]() ![]() |
