![]() | Home > Puma (Tdci) > Self inflicted electrical problem |
All-right ... more tests: but you fond out allot
![]() Immobiliser inhibiting start through the ECM (fuel or some other parameter). yes |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 ![]() ![]() |
Hi Dorset. Yes it looks like the problem is the immobiliser. Many thanks to you (and Martin) for guiding me through this.
Thanks also for the link to TechnoZen... I will contact them to explain, and see if they can fix the problem, unless you (or others) know of any other way to re-set the immobilizer. Also, I would like to find a permanent fix to avoid this kind of issue in the future. I think it is ridiculous that a simple short on a non-critical circuit (the interior lights FFS!) can cause the immobilizer to activate. This particular vehicle is an overlander, and I dread to think what I would have done if out in the middle of nowhere. ![]() |
The only other thing with 10AS in pos 07 to 2011 land rover
1. problem with 10AS immobilizer comm to the ECM wiring go to the instrument panel from 10as down to ECM have been problems with instrument panel PCB 2. the only way to check you needs a diagnostic tool to see if ECM is seeing immobilizer and also to check the set up on your 10AS 3. you 10AS has crash interrupt switch built in as your engine mechanical fuel pump. i can not remember if this stops it from cranking or just stops engine from running Last edited by dorsetsmith on 7th Dec 2018 4:56pm. Edited 1 time in total |
I'm assuming that the problem was caused by the short circuit on the interior lighting. I've never had a starting issue before, so I would think a wiring problem is less likely.
I'm guessing that a Nanocom can do the diagnostics through the OBDII, but would it be able to "re-set" the 10AS? And would the 10AS still be able to communicate to the ECM? I understand there needs to be a common code between the two. What a headache, for the sake of an interior light... ![]() Thanks again Dorset - really appreciate your help! If you ever pass through Switzerland, I owe you a beer ... or three! |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
If this was the case I would expect the starter relay to work OK, but the ECU won't receive the immob code so it won't fuel. ![]() ![]() |
Has anyone used the Gap Diagnostics IID Control tool and App?
"Looks like" it specifically has the capability to re-set the Defender alarm / immobiliser... ![]() Click image to enlarge |
I've got and used one but not on a 10AS
Cheers Martin. I will drop them an email and inquire specifically about the 10AS functionality.
Will post on the forum if I get any information which may be useful to others. |
_________________________________________________________________________________________________ 3. When the relay is activated manually, the car cranks, but does not start. All three tests with key fully turned to "Start" position. _have been thinking to day ![]() Last edited by dorsetsmith on 10th Dec 2018 9:25pm. Edited 3 times in total |
Removed the Instrument cluster today in order to access the immobilizer (as per the workshop manual):
![]() Click image to enlarge However was surprised that it not there. You can just about spot it through the dashboard, but looks like you need to remove the entire dashboard to access! Is the manual wrong or am I missing something?? I'm not exactly enthused at the prospect of removing the dashboard, so if there is another way would be good to know! |
Remove the driver's side speaker and look through the hole.
long poz drive screwdriver help too 40cm long
Thanks again Martin and Dorset! Was not looking forward to removing the dashboard - even if it looks like it could do with a tidy-up back there.
Hopefully once the 10AS is out, TechnoZen or Graffe will be able to revive it... |
So, I accessed the 10AS through the LHS speaker hole. Didn't remove it - I'm not really sure its possible through there, unless you have very small hands, and very bendy arms
![]() That said, I may not have to remove it (yet...). I spoke to Paul Brown from TechnoZen. He is VERY knowledgeable about the unit as he offers checking / re-programming / upgrade services for the 10AS. He reckons that the vast majority of faults attributed to the unit are actually connector, loom or power issues. He encouraged me to check those before removing the unit. With the aid of a connector pinout (kindly supplied by Paul) I checked: • Pin 25 permanent 12V - which was OK. • Pin 10 ignition switched 12V - which is not working – I get absolutely nothing when I turn the key. So before I remove the 10AS, I need to figure our why its not getting power on ignition. |
