![]() | Home > Puma (Tdci) > instrument Cluster and Clock Connectors |
| Pjembe Member Since: 21 Jul 2015 Location: Newbiggin by the Sea Posts: 143
Doing a little bit of work behind the dash and I have come up with bit of a problem.... How do you disconnect the clock and the instrument binnacle connectors.
I have got all the other switch connectors disconnected OK just stuck with these last two. Is there some sort of secret latch mechanism? Any advice on how to undo these connectors would be greatly appreciated and if any one has pictures, even better. |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698
Instrument pack:
Push down on tab (green arrow). This releases the latch which you swing across (orange arrow). Click image to enlarge Clock: Push down on tab (green arrow) to unlock, pull gently on connector. Click image to enlarge 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Brilliant! Thanks guys
