![]() | Home > Td5 > Knocking/tapping sound, anybody heard this before? |
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 ![]() ![]() ![]() |
possible loose clutch plate springs? I am sure someone will be along who knows better than I!
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3259 ![]() ![]() |
That’s an unusual sound as it’s not related to engine RPM
Sounds like an air leak. |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605 ![]() ![]() ![]() |
It increases with RPM.
My finger counting comes to 192 knocks per minute ![]() Nearly a quarter of the idle RPM |
Fixed.
It was a broken rocker shaft, second hand replacement £40. One of those block things highlighted in red had come off and was worn out ![]() ![]() Click image to enlarge This engine has 173,000 miles on it. |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
Blimey!! thanks for the heads up!
Glad you got it sorted. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
