![]() | Home > Puma (Tdci) > Rear Differential Knock/Click on Deceleration. Tried all. |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3787
Have you checked the rear half shafts? They give a good clunk when worn from my experience. With all4 wheels on the floor, the hand brake on and in gear, grab the prop shaft and twist it. If you hear a knock and the hubs then the half shaft splines are worn. There will be a little movement even when new, but should be minimal, maybe 1-2 degrees of rotation.
| Jamieyasa6975 Member Since: 28 Nov 2018 Location: Colombo, Sri Lanka. Posts: 3
Hi, thanks for your reply.
The half shafts have minimal to no movement. I’m wondering how it could be anything other than the Diff because the sound developed only after I dismantled the Diff to replace the bearings ? |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512
Did you follow the instructions given at the workshop manual regarding pinion height, side bearings preload, mesh, etc? Puma 110" SW
| AdrianCR Member Since: 23 Aug 2009 Location: Costa Rica Posts: 53
It happened to me exactly the same with mine replace THE A-Frame joint even though it looked good and know there is no rear sound in my rear diff. it really does not make sense
but it worked for me. |
| All times are GMT |
