Home > Puma (Tdci) > Upgrade options for driveability
Page 4 of 4 <1234
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
A remap is something I have been considering for a while.. I have a 2008 90HT which I bought second hand with 14,000 miles on the clock. It has never had any of the issues referred to by the OP and alluded to by others here. This has made me wonder whether my vehicle has already had some sort of remap? My previous Land Rovers have been petrol engine Series. This is my first Defender so I have nothing to compare the performance to.
My question is, is there an easy way of establishing whether my engine has already been given a remap prior to me taking ownership?
Post #742485 27th Nov 2018 10:41am
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Not sure. Even with the BAS tool connected, I couldn't see an easy indication of which tune was already downloaded (though it might be something you can interpret from reading off the info on software versions, not sure, I didn't do a before and after comparison). Might be worth a chat with Pete. I guess somebody who knows the software version numbers inside-out would probably be able to tell if they were the factory tune or something else, but maybe no more than that.
There are certainly good and bad vehicles, and there always have been, so you may just have an unusually good one. One of my old 300Tdi 90s (bought used from several previous owners) had less drivetrain slack with 60k miles on it than a lot of new vehicles have. When I bought my last 300Tdi in 2007, I worked at the dealership so I took every single stock vehicle for a short test run to pick the best one out of the bunch for drivetrain slack, and also looked at bodywork fit, to make sure I got a good 'un Laughing ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #742715 28th Nov 2018 10:17am
rockster57
Hi BM, thanks for the info. I’m going to follow your advice and speak to Pete.
Very envious of your former role at the dealership giving you the opportunity to inspect and compare so many Defenders. Nice one Thumbs Up
Post #742722 28th Nov 2018 10:44am
Yulong
Another BAS 150 remap here, cannot recommend highly enough!
It's like an entirely different car esp. in 3rd/4th from 30mph upwards.
Post #742757 28th Nov 2018 1:45pm
I'm afraid there's no easy way to tell, unless you can ask the previous owner.
Edit: I have no idea why I thought you were called Steve, and since you're probably not, I apologize!
Post #742828 28th Nov 2018 7:57pm
rockster57
Hi Blackwolf,
Thank you for your advice Thumbs Up
Post #743496 2nd Dec 2018 2:16am
landy andy
Not an easy way, but a tuner will know by plugging it in if it has a standard or modified map
Andy.
Post #743513 2nd Dec 2018 10:38am
andrewlandy
Austria 2016 Defender 110 Puma 2.2 USW Alpine White
Fuel?
Hi, Has anyone noticed a fuel consumption improvement since their remap?
Post #750656 12th Jan 2019 12:36am
JOW240725
I've never calculated mpg as I don't to know. But I'd doubt it has improved after remap, because it is much more fun driving with the extra power and torque. It's difficult not to put your foot down. James
Instagram @suffolk_rovers
Post #750663 12th Jan 2019 7:45am
LR90XS2011
[quote="rockster57"]A remap is something I have been considering for a while.. I have a 2008 90HT which I bought second hand with 14,000 miles on the clock. It has never had any of the issues referred to by the OP and alluded to by others here. This has made me wonder whether my vehicle has already had some sort of remap?
the OP has a 2.2 most of these have an issue with the standard map that results in the Kangarooing, the 2.4s dont normally exhibit this trait with the standard map , the ECUs etc are not the same DEFENDER 90 TDCI XS,
Post #750664 12th Jan 2019 7:53am
rockster57
^^^ Thumbs Up
Post #750665 12th Jan 2019 8:13am
Dobby
Re: Upgrade options for driveability
BogMonster wrote:
...the answer to the low range issue is to unplug the range sensor so the thing doesn't know the difference
Out of interest, how does one unplug the range sensor? Does that have any other side effects?
VMTIA,
Dobbs.
Post #750935 13th Jan 2019 1:53pm
BogMonster
If you crawl underneath there is a sensor located on the transfer box more or less above the front propshaft with about six inches of wire and a plug on a bracket. Just unplug that, optionally blank it off to stop crud getting in. I'm going to run mine up to a switch on the dash so I can choose high or low range tune in either range. Most of the time the high range tune is preferable for me, but on very rough ground there is not quite enough throttle damping so I want the ability to switch. ---
Post #751134 14th Jan 2019 12:03am
Page 4 of 4 <1234
