Home > Maintenance & Modifications > VGS privacy glass to gullwing conversion
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
This weekend started the transformation back to a proper Defender look, off came those horrendous glass panels.
Took a professional installer 30 mins each side, they were bonded on tight, and took some serious effort to break the bonding.
On went the Front Runner gullwings, and as with all things Defender, mine has 70mm radius bottom corners, the gullwings had 50mm, out came the grinder and dremel. Simple install, an hour each side once the holes were drilled to accept the frame and glass.
As you can see, it will need to go into the body shop to clean up the remaining bonding, which I took down as best as possible with a blade... but still some there, which is fine, they are going to light sand it and try and buff out any scratches.
The rear quarters and back door out this weekend
Thumbs Up
Mark
Post #742337 26th Nov 2018 3:26pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
that's looking quite nice.. Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #742338 26th Nov 2018 3:32pm
2010Blackdefender90
Thumbs Up
Post #742339 26th Nov 2018 3:43pm
L90Andy
United Kingdom 2006 Defender 90 Td5 SW Zambezi Silver
Excellent progress. A toffee wheel in a drill will get that adhesive off.
I got one to remove some old sikaflex and it made light work of it. Instagram: l90andy
2006 Land Rover 90 TD5 CSW Silver Edition
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #742345 26th Nov 2018 3:58pm
2010Blackdefender90
Will that work? the remover told me it’s very hard to remove with a wheel... but, could be worth a try Thumbs Up
Thanks
Post #742349 26th Nov 2018 4:19pm
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Might also be worth a bit of WD40 and a bit of elbow grease... I've removed all the decal adhesive using that approach... anything that was left over had a bit of G3 scratch remover paste dabbed on.
A toffee wheel will make the job a lot easier and quicker if you've got one to hand but I've used the above approach loads of time with no detriment to the original surface.
Post #742351 26th Nov 2018 4:35pm
Balvaig
I have used "sticky stuff remover" quite successfully on residues, although not on the area you have left.
Available from Amazon and B&Q.
Might be worth a try.
Post #742357 26th Nov 2018 5:07pm
2010Blackdefender90
This silicon bonding is mean stuff.. I have a toffee wheel, no harm to try it... heard WD40 has a way of softening up silicon, but this stuff VGS use is aircraft grade bonding, apparently.
Post #742359 26th Nov 2018 5:09pm
bankz5152
Much better! Nice job. Instagram @defender_ventures
Empire Tuning - Agent
Post #742375 26th Nov 2018 6:13pm
Sulisuli
Why not contact VGS and ask them what they use? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #742384 26th Nov 2018 6:56pm
2010Blackdefender90
I did, they wouldn’t say what they used, the guy who removed them, windscreen professional, said it was “industrial strength”
Post #742385 26th Nov 2018 7:04pm
Zed
Nice one. Looking better already.
Autoglym tar remover may get the worst of it off.
Post #742386 26th Nov 2018 7:06pm
mk1collector
The problem with removing the adhesive if it’s been applied correctly is that a primer should have been applied to the paint first, so you may end up having to paint the panels if the primer bonded properly to the paint. Ray
My build thread
Post #742388 26th Nov 2018 7:08pm
2010Blackdefender90
Yep, VGS installed them, before I got it. It’s been primed and it has etched into the paint in places, as it’s supposed to. They were never supposed to be removed, as VGS told me when I asked them. So, some of the bonding has gone, but, think it’s got to go in and get sorted. Thumbs Up
Thanks for all the suggestions...
Update on progress at weekend when the rears come off
Post #742391 26th Nov 2018 7:33pm
oneten110
Screwfix sell a product which dissolves silicon bonding material
Post #742469 27th Nov 2018 8:38am
