Home > Maintenance & Modifications > Rear view 7" LCD Mirror + NIGHT VISION REVERSING PARKIN
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Trying to find a better view out of my rear view mirror I find the standard one just shows a lot of the spare wheel that covers the rear door window. So Maybe retrofitting a camera somewhere above the rear door or in the rear bumper with a LCD screen attached to the original mirror would give me a better view not only while I'#m driving along but also double up as a parking aid?
Has anybody fitted one? What's the best kit, position for the rear camera, where did you pick up the live feed as it would need to be live all the time the ignition is on. Just thought I'm guessing without checking the screen cant be any bigger than the mirror due to the sun visors Big Cry
Anyway all comments and pictures would be much appreciated Thumbs Up
https://www.ebay.co.uk/itm/WIRELESS-CAR-BU...rk:21:pf:0 2010 Defender 90 HT
The longer I live..... The better I was!
Post #741141 18th Nov 2018 8:15pm
Butchers Boy
Anybody used this kit?
http://defenderupgrades.co.uk/product/land...nitor-kit/ 2010 Defender 90 HT
Post #741148 18th Nov 2018 8:55pm
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
https://www.amazon.co.uk/gp/product/B07CLS...&psc=1
I have this one.
Post #741172 18th Nov 2018 11:13pm
Ihod
Do you have a photo of that installed, please? Ian
MY2015 110 XS SW
MY2008 110 County USW - Sold
MY1962 Series IIa Truck Cab - Sold
MY1994 300Tdi 90 Hardtop - Sold
MY2001 TD5 90 Truck Cab - Sold
Post #741203 19th Nov 2018 10:12am
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
I had the defender up grades set up, but the mirror did not fit between the sun visors and the mirror mounting was all wrong so sent it back. I have seen this kit fitted but there was a lot of work cutting down the sun visors and making a custom mirror mount not OME .
Post #741206 19th Nov 2018 10:38am
2010Blackdefender90
Need to clean up the wires to headliner
Takes away all blind spots. Camera is mounted with the bracket on the rear washer jet.
Post #741211 19th Nov 2018 11:01am
Butchers Boy
Looks great! Do the sun visors still come all the way down? 2010 Defender 90 HT
Post #741212 19th Nov 2018 11:03am
2010Blackdefender90
No, but, TBH, a simple twist and they fit.
The best thing, the streaming video on the rear, zero blindspots, even when dark, and ZERO reflection in the rear view mirror back off the rear window / door, like before.
Need to connect the revering positive feed wire, and then have the back up grids on the mirror.
Thumbs Up
Post #741214 19th Nov 2018 11:23am
2010Blackdefender90
lastly, it's also a front and rear dash cam
Post #741215 19th Nov 2018 11:23am
Butchers Boy
Did you mount the rear camera inside the rear door or attach on the bodywork outside? Any pictures? 2010 Defender 90 HT
Post #741217 19th Nov 2018 11:37am
2010Blackdefender90
Outside, for a clear picture on the rear mirror.
The rear camera comes with a bracket, I slightly elongated the hole in the bracket with the dremel, removed the rear washer nozzle and put the bracket behind the nozzle, closed it all up and fitted the camera. You need to drill a small hole to feed the camera wire back into the cabin and put in a small grommet
Once the wire is in the cabin, follow the wire along the roof line back to the front, and to the mirror.
Install was 1 hour, max.
Post #741250 19th Nov 2018 4:05pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
Have you tested the parking mode yet, that seems a great feature to record when away from the car, just wondered if its any good?
Post #741262 19th Nov 2018 5:13pm
2010Blackdefender90
Not yet, I had a Blackvue dash cam hooked up before, that was powered by a small box that kept the device on for 6 hours after I locked the doors.
I will be trying to connect that power lead up, at the moment it's just plugged into a spare 12v socket under the seat.
Post #741263 19th Nov 2018 5:16pm
Snowy90
does it need a permanent live for that feature? and a separate wire.
It looks very impressive.
Post #741264 19th Nov 2018 5:21pm
2010Blackdefender90
Not sure, I never hooked that box up.... but must have been a live, the box turned it off when the voltage dropped to save the battery
Post #741268 19th Nov 2018 5:30pm
Site Copyright © 2006-2019 Futuranet Ltd & Martin Lewis
