![]() | Home > Puma (Tdci) > Judder in 5th and 6th |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
This probably isn't the news you're looking for.....
Do you get something similar sometimes when pulling away? I have noticed something similar recently - a quiet slow wobble and I suspect is could be gearbox / extension shaft but most likely friction plate related? Feels to me like the extension shaft is isolating? Good luck. |
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
Nope pulling away is fine. Unless I'm not noticing it. It's very noticeable when it happens as it feels and sounds like something is massively vibrating in the drive line.
I originally thought it would be a UJ but I've shock them very vigorously and I could see any movement. Accelerating down hill is fine. Just up hill when there is more strain applied. |
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
Is it low rpm 5th and 6th ? If so when the revs climb does the vibration stop or get less ?
| Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288
I my experience, sometimes UJ wear cant be detected unless you unbolt the propshaft.
Good luck Roy.
Not the same issue as me. Mine is a silent and only slight wobble under load. |
Relatively low and when the revs climb I feel the vibrations climb too. I've just had a look underneath after giving it a run up and down the motorway do a couple miles. The only thing I can see underneath is when I shake the rear prop the whole gearbox moves up and down. Should the mounting bushes be this soft?
Thanks for Your help so far |
| PIPLANI Member Since: 18 Feb 2016 Location: Bern Posts: 6
I have a fairly new 2015 and the same problem.A strong judder through the cabin and driveline in 5th and 6th gear.Can you please elaborate on what you found the problem to be.
no solution yet, and also as the truck is in the wife's hand for the next 2 months while I'm away, no doubt there will be more problems upon my return
Visiting my dealer in the next couple of days.Will post if we find a solution.
resurrecting my old thread, I have been living with this judder for a while now!!
Finally had enough of adjusting my driving style around the rev range! New clutch, release bearing and adaptor shaft fitted at the weekend and the vibration is GONE!!!! Just incase anyone has the same problem in the future and finds this thread, always nice to have a solution to the problem listed! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
| Noiseydave Member Since: 27 Dec 2015 Location: West Midlands Posts: 43
My 2009 DCPU does the same, under acceleration or high throttle going up hill in 5th and 6th (although 5th seems to have less vibrations) it also groans a little. Interestingly the same hill on the way home i experience the issues on regularly with a minidigger, 3 buckets, and triple axle trailer on tow in 4th has no such vibration
We rebuilt transfer case with ATB and the input shaft changed to an ashcroft kit and it made no difference although that was not why we did the work. When we removed the box, springs and friction plate looked fine although i have my doubts on the quality of the clutch fitted (original LR with 30k on it) as has been documented many times on the forum. All joints, shafts, mounts are ok, I put it down to the amount of torque being produced (car is remapped, bigger intercooler etc.). Adjusted driving style to reduce the occurrence but it would still be good to know what it could be and get it fixed. |
Did you take the clutch pressure plate off?
The actual clutch face on mine looked fine, but once removed it was like a tambourine!! the damping springs were shagged and almost to the point of falling out the friction plate. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
glad you sorted it been there, done that and got the T-shirt |
Haha it’s lasted over 2 years with the vibration but not sure how much longer it would have lasted.
Click image to enlarge Click image to enlarge Click image to enlarge They were ready for changing. Only done 42 thousand miles Instagram - @r22oyp Roy |
