![]() | Home > In Car Electronics > Brake light fuse keeps blowing ?? |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
check stop/tall light fitting
also check towing socket for water |
| G4V JW Member Since: 24 Sep 2018 Location: Northants Posts: 190
Cheers, I'll have a nose
So..... brake light housing mint, no corrosion, towing socket dry, just realised the top brake light comes on dim when the heated rear window is on, then goes bright when peddle pressed, also no rear wiper or rear door central locking ? Instagram; @gavin_walding
You have bad earth or water shoring out elect connectors
Click image to enlarge make shore connector Plug C0704 ok just realised the top brake light comes on dim when the heated rear window is on, then goes bright when peddle pressed, also no rear wiper or rear door central locking power back feeding if the top brake light comes on dim when the heated rear window is on (water shoring out elect connectors ) as they are two CCT power form two places Click image to enlarge Connector Plug C0704 is the common point for both cct check it for short out and the earth C0565 is down under on the transfer box Click image to enlarge Click image to enlarge Click image to enlarge Last edited by dorsetsmith on 14th Nov 2018 7:57am. Edited 9 times in total |
up date ^ good hunting
Blimey
1. rear wiper cct uses connector Plug C0704 too and earth go down under on the transfer box 2. rear door central locking wiring independent go up roof and down too drives side A pillar at top of windscreen under head lining gray plug |
Legend mate, cheers for that
Only provide information you have to fix it
