Home > In Car Electronics > Brake light fuse keeps blowing ??
G4V JW
As above, third one in a week, where should I look first ?
Thanks in advance Instagram; @gavin_walding
Post #739546 9th Nov 2018 5:19pm
dorsetsmith
check stop/tall light fitting
also check towing socket for water
Post #739566 9th Nov 2018 7:59pm
G4V JW
Cheers, I'll have a nose Thumbs Up Instagram; @gavin_walding
Post #739576 9th Nov 2018 8:31pm
G4V JW
So..... brake light housing mint, no corrosion, towing socket dry, just realised the top brake light comes on dim when the heated rear window is on, then goes bright when peddle pressed, also no rear wiper or rear door central locking ? Instagram; @gavin_walding
Post #740390 13th Nov 2018 9:05pm
dorsetsmith
You have bad earth or water shoring out elect connectors
make shore connector Plug C0704 ok
power back feeding if the top brake light comes on dim when the heated rear window is on (water shoring out elect connectors ) as they are two CCT power form two places
Connector Plug C0704 is the common point for both cct check it for short out
and the earth C0565 is down under on the transfer box
Post #740401 13th Nov 2018 9:26pm
G4V JW
Cheers Thumbs Up that as easy as it sounds, just trace back to chassis ? Instagram; @gavin_walding
Post #740405 13th Nov 2018 9:44pm
dorsetsmith
up date ^ good hunting Whistle
Post #740422 13th Nov 2018 10:36pm
G4V JW
Blimey Shocked Instagram; @gavin_walding
Post #740463 14th Nov 2018 9:57am
dorsetsmith
1. rear wiper cct uses connector Plug C0704 too and earth go down under on the transfer box
2. rear door central locking wiring independent go up roof and down too drives side A pillar at top of windscreen under head lining gray plug
Whistle
Post #740483 14th Nov 2018 12:08pm
G4V JW
Legend mate, cheers for that Very Happy Instagram; @gavin_walding
Post #740524 14th Nov 2018 5:41pm
dorsetsmith
Only provide information you have to fix it Whistle
Post #740526 14th Nov 2018 5:45pm
