Home > Maintenance & Modifications > Side Locker - Insulation - Is it necessary? |
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 |
I'm planning to get this fitted this weekend.
Click image to enlarge Click image to enlarge While checking the dimensions and fitment, I've become concerned about the heat radiating off the exhaust and rear silencer. I'm going to fit a compressor, air line, snatch strap, jumper cables and tyre repair kit but worried the potential heat could melt the insulation and plastic bits. Trawled through the many posts on these type of lockers and insulating them is never mentioned. For the fine members out there that have one fitted, feedback on my heat concern would be greatly appreciated... I've never used insulation before, so presume that something like Dynamat would not work as it would get destroyed by stones, etc. flying off the tyre? And putting the insulation on the inside of the locker would serve little purpose? Much Thanks in advance... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
13th Nov 2018 3:16pm |
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 |
No direct experience of fitting these, but some insulation would be a good idea, if your putting electrical equipment i there, I think Silent coat is stronger/thicker than dyna matt and cheaper.
I have heard people putting it under wheel arches to stop stone chips and sound deadening, so should hold up pretty well and you can always recover the underside of it. |
13th Nov 2018 4:10pm |
I purchased it from Big Country http://www.bigcountry.co.za/contact-us/ It was on a clearance sale and think they only had 3 available, also not sure what postage would be to the UK! Put 'side locker' in the search function, there are many manufactures closer to you, Terrafirma pops to mind... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
13th Nov 2018 4:41pm |
Thanks for the suggestion Will have a look if it is available down here... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
13th Nov 2018 4:43pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1031 |
I think you’re over thinking it, the heat from the exhaust at that point is about the same as a sweaty nutsack after a 3 mile jog.
I’ve got a gas bottle fitted in the same place, doesn’t even get warm after hours of driving |
13th Nov 2018 7:54pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7706 |
I have a plastic on board water tank there, it doesnt get warm from the exhaust. I dont think it will be a problem. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
13th Nov 2018 8:48pm |
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 401 |
^^Me too^^ I've never even thought to check the tank but the water comes out cool so it's obviously not a problem.
13th Nov 2018 9:21pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
if you’re going to ‘plumb” in” the compressor so it will operate without the door being open then I would look at venting the box. If there’s a chance of heavy compressor use then insulation is only going to build up heat inside which will more than likely give issues with the compressor further down the line.
I’ve had one installed for a couple of years and even on a good 4hr run the side nearest to the exhaust doesn’t even get warm to the touch. |
14th Nov 2018 1:01am |
Surfed around last night and Dynamat / Silent Coat is hellishly expensive over here...
Thanks for all the replies... Indeed I was probably over thinking it, but not anymore The compressor will only be used with the door open, for inflating tyres, etc. Will do a post on the install once done... Always love the wealth of knowledge and humour on here Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
14th Nov 2018 6:06am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2600 |
looks good bushpig --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
14th Nov 2018 9:52am |
Thanks for the compliment Naks, but still getting on with the installation... will do a post when completed...
I've had a thought on installing a door switch (or whatever switch will be best suited?), wired in with the safari door, to give a layer of security to the locker. Anyone out there think that this will confuse or cause issues with the 10as? Basically if the vehicle is locked and alarmed, and a hoodlum breaks into the locker, I want the alarm to sound... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
24th Nov 2018 1:35pm |
Made a new post https://www.defender2.net/forum/post743097.html#743097
To Badger110, James and Whirly90… Indeed heat is a ’No Issue’ did a trip to Cape Point; highway, b roads and puttering around the reserve and the locker got warm, actually barely noticeable. Thanks again to all for the suggestions and advice Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
30th Nov 2018 6:10am |
