Home > Puma (Tdci) > Purple live in a 110 USW
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Apparently there is a purple live connection in the rear of a 110 behind the rear speaker.
Mine is a Utility Station Wagon, XS spec, MY2010 (Oct 2009) and I haven't noticed a rear speaker.
Is it meant to have one? or was this missed on the utility models?
Reason I ask is I have just ordered a Labcraft Scenelite S18 and am trying to plan the installation.
Post #739998 12th Nov 2018 10:55am
MartinK
You need this thread https://www.defender2.net/forum/topic20319.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #740015 12th Nov 2018 12:10pm
The rear speakers are built into the light covers, on each side inside the rear door. All XS models have them.
The purple wire on a vehicle of yours' age should be behind the drivers side cover but is sometimes taped up with the towing electrics and concealed behind the mud shield at the rear of the wheel arch. Darren
Post #740016 12th Nov 2018 12:11pm
kmac
Thanks both. Just saying I've never noticed a speaker there - will have to check when I get home. Certainly never detected any music coming from the back when I have the radio on.
But if it is standard with XS spec, then must be there.
Post #740029 12th Nov 2018 1:07pm
MartinK
If you look at the linky above (in my first post), there's lots of info reading down the thread about where people have located that Purple wire on different specs and different vintages of Puma and TD5...(as Darren alludes...) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #740043 12th Nov 2018 2:41pm
kmac
Great thread - thanks again
Post #740062 12th Nov 2018 4:28pm
MGRGPGBG
United States 2009 Defender 110 Puma 2.4 SW Alpine White
This power feed was in mine also, made it easy to add a double USB Plug / Charging port right in the rear speaker panel.
Post #740273 13th Nov 2018 1:42pm
