![]() | Home > Puma (Tdci) > Purple live in a 110 USW |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2666 ![]() ![]() ![]() |
You need this thread https://www.defender2.net/forum/topic20319.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
The rear speakers are built into the light covers, on each side inside the rear door. All XS models have them.
The purple wire on a vehicle of yours' age should be behind the drivers side cover but is sometimes taped up with the towing electrics and concealed behind the mud shield at the rear of the wheel arch. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
Thanks both. Just saying I've never noticed a speaker there - will have to check when I get home. Certainly never detected any music coming from the back when I have the radio on.
But if it is standard with XS spec, then must be there. |
If you look at the linky above (in my first post), there's lots of info reading down the thread about where people have located that Purple wire on different specs and different vintages of Puma and TD5...(as Darren alludes...) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Great thread - thanks again
MGRGPGBG Member Since: 19 Dec 2017 Location: New York Posts: 67 ![]() ![]() ![]() |
This power feed was in mine also, made it easy to add a double USB Plug / Charging port right in the rear speaker panel.
