Home > Technical > 90 Puma Hardtop Arch height Help please. |
You can remove tyre size from the list of variables by measuring from the wheel centre. Darren
6th Nov 2018 11:02pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7710 |
i know, but i thought people might find that harder guessing the middle of the rim esp if the logo is the wrong way up!.... i was trying the simple. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
6th Nov 2018 11:04pm |
Fair enough Darren
6th Nov 2018 11:16pm |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 706 |
Hi JST, whilst not specifically answering your question, there are a few measurements here which may help.
https://gwynlewis4x4.co.uk/wp-content/uplo...rments.pdf 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
7th Nov 2018 6:28am |
great link thank you.
mine are 285mm front (std 250-260) and 280 mm rear (std 300) working off Gwyns measurements. so too high at front and too low on rear! swapping them around would help possibly not sure on front spring rates though. Time to find some std springs. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
12th Nov 2018 3:54pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4950 |
What we used to say back in the days of the 306. " that needs a 40mm drop and some cyclone alloys"
thats an old peugeot 306 joke from back in the day I would fit good standard springs alround or a decent quailty upgraded one if you have the budget. I am thinking on changing my terramera stuff, as i dont rate the dampers at all. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
12th Nov 2018 9:43pm |
I will go genuine if i change them, or oem equivalent . Its running tf springs and shocks both of which are shocking..... Cheers
12th Nov 2018 9:50pm |
