Home > Td5 > Steering wheel puller
alexatnd
Really really simple question
Removing steering wheel so I can replace the horn stalk
Needless to say undoing the nut slightly and heaving on steering wheel ain't doing anything. The Haynes manual says build your own steering wheel puller utilising the 2 threaded holes steering wheel. Fair enough ... but it's useful if haynes actually tell you the size of the threaded holes!
The workshop manual doesn't tell you either!
Can anyone help ?
Rgds
Alex Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #738549 4th Nov 2018 2:15pm
gilarion
Before you buy or make a puller leave the centre nut on loosely then try rocking the wheel while pulling, a quick squirt of WD 40 on the threaded shaft may help as well. Just make sure you leave the nut on the last few threads because if it comes off suddenly you can get a right smack in the mouth. Eventually, with pulling and rocking the wheel from side to side it should come free of the splines unless of course, some daft Censored has used Loctite on the splines. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #738565 4th Nov 2018 3:19pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Presumably you're talking about the standard LR steering wheel with the big pad on.
I've just been and had a look at my spare one in the garage, there are two holes through the rubbery coating, one each side of the centre but below the centre line, I thought at first M8 and shoved a bolt down the hole, it was tight in the rubber but not catching to anything, I then tried an M10, even tighter but still not catching, they don't appear to be threaded.
To be honest, I've never needed a puller when removing one myself, just undo the nut a few turns as you say and pull, usually find a wiggle as you're pulling helps to loosen it.
Post #738568 4th Nov 2018 3:30pm
grafty99
A quick whack on the side facing you with the palm of your hand works well too. Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #738579 4th Nov 2018 4:27pm
grafty99
Where the spokes join the rim Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #738581 4th Nov 2018 4:30pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
As stated previously, all excellent advice. Further to these... with the nut loosened but not off, turn the wheel so a spoke is vertical. You now have enough room to hit it under the steering column. Then whack it with a dead blow hammer. Turn it so the other spoke is vertical and do it again. If you don’t have a dead blow use a mallet and strike it nearest the centre not at the rim. This should free it up.
Good luck 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #738594 4th Nov 2018 5:19pm
hank
m6 suited mine when I homebrewed a puller
Post #738598 4th Nov 2018 5:26pm
VVS210
Never needed a puller, loosen the nut then pull on the wheel with a rocking motion from one side then the other & don't be afraid to swing on it a bit :thumb-sup
Post #738605 4th Nov 2018 6:08pm
dorsetsmith
Post #738606 4th Nov 2018 6:13pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
On mine I undid the nut flush with the top of the thread. Then hit the nut with a mallet a few times whilst my mate was supporting the steering wheel and pulling it towards him. The shock frees off the wheel 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #738670 4th Nov 2018 10:06pm
alexatnd
Many thanks for all the useful advice
A friend made up a puller from an old horseshoe he had lying around, I'll try a few of the suggestions before trying that ... and yes the screw holes are M6 ...
Rgds
Post #738731 5th Nov 2018 12:13pm
alexatnd
... and it worked ... less than 60 secs to fit puller and get the wheel off... happy bunnny!
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #740000 12th Nov 2018 11:01am
grafty99
1990 Vogue SE
Post #740195 12th Nov 2018 11:02pm
