Home > In Car Electronics > Interior LED light upgrades |
Mike_E Member Since: 13 Apr 2017 Location: Aberdeenshire Posts: 160 |
Hmmm that sounds like a bit of a worry. Try flipping them around the other way in the holder.. read that in another thread.. circuit might have a diode in it or similar.
31st Oct 2018 11:30am |
The interior lights share a fuse with the stereo and clock. The back plate of the interior lights is permanently live and it's very easy to short them out when fitting non-standard bulbs. For this reason, I insulated the fittings on mine with some plasticard to shield the back plates : Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
31st Oct 2018 11:47am |
+1 here Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
1st Nov 2018 10:46am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7866 |
Good idea LRA, thanks. James
1st Nov 2018 12:54pm |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
[quote="LandRoverAnorak"]I've just fitted three of those festoon LED's from Conrads and they're (literally) brilliant. A very nice warm white light with no low powered glow like the cheap ones that they replaced.
Click image to enlarge I think I'd like to do the same but with blue. Can you fine people confirm I have the right bulbs? And size at 36mm? I have measured mine, and I thought it came out at 38mm, but I don't see a 38mm Click image to enlarge Look forward to hearing from you Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
6th Nov 2018 11:05pm |
you can get 36mm or 39mm festoons. 39's fit.. but 36mm are the originals as far as I know.
mike |
7th Nov 2018 6:32am |
Thanks Mike. Regards
7th Nov 2018 4:46pm |
just checked the festoons from Conrad.. 39mm.
they are a step change from the nasty harsh blue-ish white cheapos from Ebay. Exactly the same colour balance as the original incandescent bulb, just a massive step change in light output. To be honest these ones have 6 emitters per festoon, they do a 3 emitter version for half the light output and for the front light above the driver it would probably be enough! not had a chance to try the light bars yet - car only just back after 1.5 weeks in the paint shop and getting a new ignition barrel and lock set fitted Mike |
7th Nov 2018 9:56pm |
Cheers for the reply.
On another note.. In relation to the lights.... I ordered a Terrafirma snow cowl from amazon... £39.99 bit expensive but I trust amazon and like the money back guarantee.. Anyways it was supposed to arrive on the 5th, so dropped them an email on the 7th letting them know it hadn't arrived, they said they could send one out Monday over night, if I wanted...... Well I'd actually seen the same thing cheaper on another site, so asked for a refund.. Then I looked for it but couldn't remember the site I went on.. So popped do to ebay and found the same Terrafirma snow cowl, even cheaper than the cheap site at 22.99.. Which meant I could buy the lights, and dash lights for less than what I was going to pay for the snow cowl! BONUS! Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
9th Nov 2018 1:57am |
Ha, good result.
Also what a coincidence as I just fitted a mudstuff snow cowl last night! I think I've probably paid over the odds though given your eBay find. |
9th Nov 2018 5:43am |
Time will tell.
It says Terrafirma, but I'll update when I see the quality 😉 fi gers crossed though. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
9th Nov 2018 5:17pm |
Just to close this one out.. tried the LED bars last night in the car. the colour balance is great, not harsh at all.
https://www.atenlighting.co.uk/50cm-slim-led-fitting.html I ordered bright, warm white, 50cm long. Mounted on the side panels its really bright on the eyes, not really useful when you stand at the back of the car as you are squinting. The light is quite directional too, the LED bars have to be angles down ~45deg towards the floor to get the best use of them. best option in my opinion - a single 1m long bar mounted above the rear door, 45deg downwards, facing forwards. No shining in the eyes and in conjunction with the LED Festoon bulb its like blackpool illuminations in the back! I'm mounting the 2-off 50cm ones above the rear door in this fashion over the next week or two. mike |
12th Nov 2018 6:47am |
Nice. Maybe look at getting one.. the list for the defender just keeps growing, I seem to be getting further away from the goal lol Regards
12th Nov 2018 10:18am |
Also to come back on this from my earlier experience. Fuse replaced (stereo and clock working again) and the interior bulbs are working properly now. The Aten blubs now work properly and are a great bright warm light, not the rather harsh white light I had previously, so now very pleased. James
12th Nov 2018 10:21am |
