![]() | Home > For Sale & Wanted > [Wanted] Td5/VDO gauge bulb holders and connectors |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Hi all,
I seem to have misplaced two of my gauge bulb holders for the VDO vision or TD5 fuel/temp gauges. These are the small black plastic T-shaped holder with the two 4.8mm blade terminals on the back. Hoping someone might have some of these lying around, I am after two if possible please? Also if anyone has an old/butchered td5 binnacle loom I am after the three way terminal housing which is used on the temp and fuel gauge and the 2pin connectors for the above bulb holders. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thanks Paul! Sorry I had missed you reply.
I am sorted though for now thanks. I will be in touch if i find that i need any more though. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
OK
![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
