Home > For Sale & Wanted > [Wanted] Td5/VDO gauge bulb holders and connectors
rallysteve
Hi all,
I seem to have misplaced two of my gauge bulb holders for the VDO vision or TD5 fuel/temp gauges. These are the small black plastic T-shaped holder with the two 4.8mm blade terminals on the back.
Hoping someone might have some of these lying around, I am after two if possible please?
Also if anyone has an old/butchered td5 binnacle loom I am after the three way terminal housing which is used on the temp and fuel gauge and the 2pin connectors for the above bulb holders.
Cheers,
Post #736334 23rd Oct 2018 1:27pm
PaulMc
Steve,
I don't have the bulb holders.
They're Land Rover part no - YAJ100390
They can be had for a little less from VDO, as part number - 800-005-019
There's also a holder that looks identical in the VDO Marine range, part number - N05-800-218
I have the connectors and terminals to fit these bulb holders -
As well as the VDO 3-way connector, supplied with terminals to suit 0.5 -1.0mm² cable -
PM me for details.
. Paul.
Post #737658 30th Oct 2018 8:10pm
rallysteve
Thanks Paul! Sorry I had missed you reply.
I am sorted though for now thanks. I will be in touch if i find that i need any more though.
Cheers,
Post #738162 2nd Nov 2018 10:21am
PaulMc
OK Thumbs Up Paul.
Post #738203 2nd Nov 2018 3:50pm
