![]() | Home > Pictures & Video > Photo request - 255x85R16 tyres on a 90 |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
If you have 255x85R16 tyres on a 90, please could I see your photos? Thank you.
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480
2" lift
std height Cheers
Standard height. I think they look perfect on a 110 but thinking they may be too big for a 90, hoping to see.
Thank you for the photos. That dude must be strong, pulling Defenders over the ridge with his bare hands! MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Sorry havent got a std height 90 with them on. got Puma with 35mm lift with them on? that any good? Cheers
| Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 732
255s on 30mm spacers and standard suspension
Click image to enlarge 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
thats nice, which hood is that? Cheers
| pux146 Member Since: 30 Apr 2018 Location: Wiltshire Posts: 121
These are on standard height 90, before I changed them.
Click image to enlarge 2007 2.4 90 fettled & remapped. |
Thanks all so far. Pux was there a reason, other than being worn, for changing them?
Keep the photos coming please MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
The main reason was they were worn, I put my 265/75/16 on just because I had a set in the garage. 2007 2.4 90 fettled & remapped.
Thanks JST, from memory it was All Wheel Trim but the 90 was sold 5 years ago so difficult to check. The only complaint was that it used popper studs to attach to the body and they were forever coming undone. 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
I like the 255/85/R16 a lot more than the 235 I had before.
Blackwolf kindly pointed me in the right direction with the 255's last year. There is no need for spacers either, and the lock stops aren't bad at all to adjust. They have a better footprint and much better ride to them, and I'd say better off road too. I'm using Dynabeads in mine. And keep an eye on tyre pressures as they can get a bit wallowy if pressures get a little lower than they should be. ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ Last edited by custom90 on 29th Oct 2018 5:48pm. Edited 1 time in total |
tyre pressures in that they loose pressure on yours? Cheers
Nothing more than what you'd normally expect.
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
they shouldnt loose any really. i only have 1 alloy from 30 that looses pressure and thats a bad valve which i just havent got around to changing. Cheers
