Home > Pictures & Video > Photo request - 255x85R16 tyres on a 90
JOW240725
If you have 255x85R16 tyres on a 90, please could I see your photos? Thank you. Thumbs Up James
Instagram @suffolk_rovers
Post #736865 26th Oct 2018 1:38pm
jst
std height, or lifted? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #736867 26th Oct 2018 2:11pm
jst
2" lift
std height
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #736869 26th Oct 2018 2:14pm
JOW240725
Standard height. I think they look perfect on a 110 but thinking they may be too big for a 90, hoping to see.
Thank you for the photos. That dude must be strong, pulling Defenders over the ridge with his bare hands! Rolling with laughter James
Post #736870 26th Oct 2018 2:20pm
jst
Sorry havent got a std height 90 with them on. got Puma with 35mm lift with them on? that any good? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #736873 26th Oct 2018 2:35pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
255s on 30mm spacers and standard suspension
 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #736878 26th Oct 2018 3:25pm
jst
thats nice, which hood is that? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #736888 26th Oct 2018 4:47pm
pux146
These are on standard height 90, before I changed them.
 2007 2.4 90 fettled & remapped.
Post #736922 26th Oct 2018 7:21pm
JOW240725
Thanks all so far. Pux was there a reason, other than being worn, for changing them?
Keep the photos coming please Very Happy James
Post #736940 26th Oct 2018 8:27pm
pux146
The main reason was they were worn, I put my 265/75/16 on just because I had a set in the garage. 2007 2.4 90 fettled & remapped.
Post #736966 26th Oct 2018 9:57pm
Harry.O
Thanks JST, from memory it was All Wheel Trim but the 90 was sold 5 years ago so difficult to check. The only complaint was that it used popper studs to attach to the body and they were forever coming undone. 2005 Td5 110 Hardtop
Post #737376 29th Oct 2018 2:01pm
I like the 255/85/R16 a lot more than the 235 I had before.
Blackwolf kindly pointed me in the right direction with the 255's last year.
There is no need for spacers either, and the lock stops aren't bad at all to adjust.
They have a better footprint and much better ride to them, and I'd say better off road too.
I'm using Dynabeads in mine.
And keep an eye on tyre pressures as they can get a bit wallowy if pressures get a little lower than they should be.
Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #737377 29th Oct 2018 2:08pm
jst
tyre pressures in that they loose pressure on yours? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #737396 29th Oct 2018 4:21pm
Nothing more than what you'd normally expect. Thumbs Up ____\We|Will|Win/___
Post #737405 29th Oct 2018 5:48pm
jst
they shouldnt loose any really. i only have 1 alloy from 30 that looses pressure and thats a bad valve which i just havent got around to changing. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #737431 29th Oct 2018 7:58pm
