![]() | Home > In Car Electronics > Led v halogen ...advice please |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
1) No, so long as it's still standard 55w versions I used Philips Extreme years ago which were great.
100w are not legal for road use. 2) No, in fact they should be slightly better than standard fit. Without an upgrade loom however, you won't get full benefit of them with output, I.e. They could do a little better. 3) Compared to higher level offerings I.e Speaker or Nolden it's very questionable. More an image thing than output. Brands mentioned currently have the highest output. I have Nolden so am biased but if it wasn't for these two I'd probably go the Wipac Crystal route. 4) LED's do not require an upgrade loom either, they will reduce the current load to 2.4A approx via the standard switch compared to around 9A as standard load. It is the current load via the switch which can cause failiure over time, the higher the load the more likely it will cause problems long term. Without the loom it won't be an issue with LED's, or with a loom with LED's it won't be a problem. So you can have either. I use a Land Reiziger loom and Noldens on mine, it reduces the switch load again to around 0.3A approx. But you don't have to do this, I have it because I chose to and reduces the load even further. It also is backward compatible too with Halogen, not that I will be swapping back. A loom is simply wiring bundled neatly together with various terminations. An add in wiring section basically with various terminations and functions. The key is here with these wiring looms is they are built for you ready to fit, they don't need constructing from scratch which is not difficult but can be time consuming. Hope this helps a little with your decision. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5982 ![]() ![]() |
Crystal clears, and good quality bulbs for me.
I am an absolute Wipac Crystal and upgraded wiring loom fan. This setup has done me proud for many years. For a low cost upgrade you will not get better. When it comes to choosing the wiring loom, buy quality not cheap. The parts used in the budget looms are just not up to spec at all. Tell you the truth if you are handy with the tools the loom is dead simple to DIY.
The problem with quality LED headlights (Speaker or Nolden) is the price, but if you can justify the cost the light output is amazing. I will be posting on this later this week as I have just upgraded to a set of JW Speakers. ![]() ![]() |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1894 ![]() ![]() |
Still looking forward to the 'big reveal' geobloke!
But I have to add my weight to the improved loom option. I put in the Landreiziger option, and the difference in output against the old, standard lights was really significant and well worth having. What's involved? Essentially 5 steps: 1) fit the relays in a suitable location - drill a small hole in the wing, screw in a self-tapper; 2) find an 'earth point' - you can use the same hole as the relays in step 1 3) connect the power cable to the alternator ( involves taking the alternator cover off, and connecting a cable); 4) connect the plug in the loom to one of the existing headlamp plugs 5) route the wiring to the headlights, and plug the bulbs in. I would say to be sure you get a loom that fits your engine/layout, rather than buying something else and giving yourself more work in trying to make it fit. The loom - about £100 I think. New light units and bulbs would be up to you, but I'd fit the loom first and then see if you think you need anything else. As Steve has said above, even if you go for LEDs in future, the loom doesn't affect that in any way. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Good grief the natives are getting restless... ![]() ![]() |
Calder Member Since: 16 Oct 2018 Location: UK Posts: 8 ![]() ![]() ![]() |
Amazing! Thanks everyone for the speedy and helpful replies.
![]() I'm worried that I won't be able to upgrade the loom myself. So the cost of doing so means that I'm looking at a bill of £200 on parts + labour = £300-ish. However, if I go for JW Speaker Evo2, I can pick these up for £460 and fit them myself (I'm not mechanical but even I can operate a screwdriver... famous last words). For an extra £160 it might be better option in the long run. |
Doh!
I haven't allowed for the VAT. |
And there you go... Justification...
![]() ![]() Just to add to both options (Wipac or Speakers) add another £30 in for stainless steel head light bezels and fixing kit... There are forum sponsors that might do you a deal (not saying they will mind) if you drop them a line. If it will help add weight to the Speakers I am happy to do that write-up this evening for you... and Don... |
I really like LED’s but for price you cannot beat Crystals. I ran them a long time as an intermediate upgrade if that makes sense.
What ever you fit, be sure to get them aligned too. Very cheap to have sorted out. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1785 ![]() ![]() ![]() |
Personally wipac crystals and one of the plug in upgrade looms you can get if you're not happy DIYing the wiring. I'm just a fan of halogen light for driving by over LED!
EastFreo Member Since: 24 May 2014 Location: Perth Posts: 103 ![]() ![]() |
I went a loom upgrade and then replaced bulbs with the Phillips Extreme Vision. Found a site called Powerbulbs.com which sells much cheaper than I can get here in Australia and they are shipped usually within days. In fact I ended up going on a bulb replacement frenzy after I saw the difference from the new Phillips bulbs and replaced all our farm Utes as well.
200£ cost of the loom? Gold plated wires or what? The Landreiziger loom with ceramic connectors is yours for 39.50 Euro plus shipping. Link below. Eric https://shop.landreiziger.nl/modificatie/m...toren.html You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
I fitted Wipac crystal with Philips Xtreme bulbs - a significant improvement over standard fitment for about £60. Have got the additional loom but haven't fitted it yet.
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3854 ![]() ![]() |
I bought wipac crystals / upgraded philips bulb and the loom.
2 years ago I fitted the lenses and bulbs... Not yet fitted the loom as like you don't want to blow anything up. They are better yes, but jump in my wife's car wil Xeons and they are nowhere near as good. I'm happy though and not had an issue? another thing to factor in depending upon where you live is that come winter and if we get snow, not sure the LED's are 'as' good as melting as they don't get anything like as hot. I would be tempted to try the bulbs and lenses first. This was mine after changing one side. ![]() Click image to enlarge |
