Home > In Car Electronics > Rear Speaker Cables
bigfatsi
United Kingdom 2003 Defender 110 Td5 CSW Aintree Green
Rear Speaker Cables
Hi Everyone,
I have a 2002/3 110 TD5 CSW. It only has the 4" speakers in the air con bar and none in the rear.
Does anyone know if the standard loom has the cables for rear speakers so I can just tap into them? Or do I have to feed cables right back from the head unit?
Many thanks in advance.
Simon
Post #734688 14th Oct 2018 3:29pm
Romadog
I would expect the wires to be there.
Just take a look behind the wire covers in the rear first.
Post #734691 14th Oct 2018 3:42pm
bigfatsi
Any idea what I should be looking for? There's no empty connectors or anything behind the panel.
Thanks,
S
Post #735505 18th Oct 2018 11:13am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Might be easier to pull the radio out and see if they're connected at the plug, if they are in there they should be the following colours: -
black/yellow - black/orange = left rear speaker
black/green - black/blue. = right rear speaker
This is taken from the MY2002 wiring diagram, it shows that group of wires as "REAR SPEAKERS FOR SOUTH AFRICA ONLY" but my 90 has them from the factory so I'd take that with a pinch of salt.
Post #735521 18th Oct 2018 12:31pm
landy andy
All my Def’s have had the wires and connectors. They are just two wires with small female blade connectors on the end.
Post #735522 18th Oct 2018 12:41pm
TBH I'd run new and better than the standard rubbish used
Post #735524 18th Oct 2018 1:01pm
bigfatsi
Cheers for the replies.
I'll have a closer look later this afternoon.
Wish me luck!
S
Post #735526 18th Oct 2018 1:39pm
