![]() | Home > Wheels & Tyres > 235 or 265? |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
235 will give slightly better turning circle and I guess marginally better mpg. I went with 265, purely looks really, maybe better high speed cornering? James
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3784
Thanks James.
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
265's will have an impact on turning circle - you may have to adjust the lock stops to prevent rubbing. I doubt you'll be able to tell the difference in terms of handling and fuel economy, though. Darren
Thanks all. Would 265βs be 265 75 16?
Yes, that's right. Darren
265x75R16 or 235x85R16 have pretty much same standard rolling circumference. James
| justinp Member Since: 24 Jun 2016 Location: Cambridge Posts: 167
Surprisingly my mpg improved slightly when I went from 6 year OE continental 235/85r16 to brand new BFG 265/75r16.
I had to adjust my steering lock stops which I had previously adjusted to give me the best turning circle on the 235βs, but I suspect if I hadn't adjusted it before, it would probably have been fine with the 265βs. Now gone - 2012 2.2 110 DC XS |
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441
Put 265s on mine when it was about 6 months old. Didn't adjust the stops and has been fine. Bfg a/t spring/summer, Bfg mud autumn/winter.
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21028
You can go 255/85/R16 with out spacers and just a little steering lock stop adjustment if you wanted to.
Depends if that tyre size is available at the moment, I'm guessing maybe not or not yet? ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18037
255/85 is only available as KM2, whereas 235/85 and 265/75 are available as KO2, KM2, and possibly KM3.
Not sure about the KO2 ATR in 255/85 but I heard the KM3 will be shortly in that size but likely not just yet. ____\We|Will|Win/___
Thanks guys, 265βs ordered.
| sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283
Hi All, just picking up on this thread. I have heard that 265's are too big for standard alloys on ddci 2007, is there any truth in that? just making my decision and wanted to double check as I had not heard this previously Sweatysock
------------- 110 CSW TDCI (Puma) 2007 |
| WindyJ Member Since: 18 Oct 2018 Location: France Posts: 190 |
BFGoodrich quote 7β-8.5β for rim size with 8β the recommended. I believed the boost alloys are 7?
