![]() | Home > My Defender > The Latest - 2011 110 CSW XS |
| 22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153
Mine also doesn't leak. I told my dealer and Landrover rang me and asked me to take in so they can correct the problem and give me my leaks - I paid for them afterall! 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
Metallic grey is stunning ... If I ever wrap my defender it will be metallic grey the way the light catches all the contours looks amazing.
Having said that JSG ... Do you have a list of "new defender" jobs to do like Zag? |
| TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752
Good to see the new one's finally arrived John
Just stuck another 2200 on mine in the last week, , all still good, bar a re fix of the driver's door weather seal to be done sometime,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
| JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412
Nothing major The cubby box needs replacing as the standard one is too low for resting your elbow on and an aftermarket one will be easier for fitting some 12v sockets into. The number plate will get swapped out soon as well. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Just go back from a week in France and it now has just under 1,000 miles on it. All seems well but on the odd occasion it seems to have a 'transmission' judder / rattle when coming to a stop after cruising (ie at the toll booth etc). Couldn't get it to happen yesterday though. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
| CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803
That sounds like the familiar handbrake binding noise, heats up after a run and causes the judder as you come to a rest Andy
| pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
if you don't mind me being cheeky did you pay list or get some off ?
Pom |
Thanks for that - what is the fix, just slaken it off? John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
I got a bit off list I was told by a dealer on here that they couldn't match the price I paid so I was quite happy http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
I believe so yes, it's something to do with the heat build up on a long journey, think there will be some posts on here about this as I remember it was quite a common issue. Andy |
Never had it on any of the previous ones,, but as Andy says, sure there has been a few topic#s on possible handbrake drum ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Went in to the dealer today for the rear step / tow bar to be fiited along with the wing top protectors as they had come in whilst I was away.
They also adjusted the rear mudflap, adjusted the handbrake (to see if fixes the occasional rattle) and washed it for me. New rear step. Click image to enlarge Wing tops. Click image to enlarge John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Just the plate, RAI and privacy glass to do John, then it will look like mine
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Main Brian James Trailer Dealer for South West UK |
It may well end up with a RAI for dust prevention and the plate will be changed soon (once the novelty of a 11 plate has worn off
I have some jate rings I kept from the 07 to go on the front and will prob change the tow ball to a pin type as well. Still fancy some 265s ........ http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
| All times are GMT |
