|  | Home > Puma (Tdci) > Bubbling on wing mirror arms |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935      | Under warranty - Yes. | ||
|  27th May 2011 3:56pm |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785      | Yes. I had mine changed a month ago under warranty. Russell
 2011MY 110 XS USW Black | ||
|  27th May 2011 4:46pm |
| galawaygreen Member Since: 16 May 2011 Location: Lincolnshire Posts: 132    | They must be crap mine are only a few months old | ||
|  27th May 2011 4:52pm |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935      | They vary. Mine are 15mths old and pristine. | ||
|  27th May 2011 9:38pm |
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266      | A lot of the issues are down to quality,we never had problems with mirror arms,headlamp bezels on earlier Def's the folding steps are a joke they start rusting within weeks, we are on our second pair of mirror arms,third set of H/L bezels and all the steps replaced. 2.4 90 XS
 1968 1/32 scale Britains 109 Pick up. | ||
|  28th May 2011 8:27am |
| eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586      | Same for me - mine were just changed under warranty. | ||
|  28th May 2011 8:56pm |
| Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610    | If out of warranty, these are very cheap to buy anyway. A new mirror and arm assembly can be as cheap as £15 per side. | ||
|  28th May 2011 10:49pm |
| Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026    |
 Roughly the same for a rim rusty headlight, and window catches, after market bumpers, rear folding steps, mudflap brackets etc that can also rust are peanuts so can always buy new if out of warranty and paint or treat it before you put it on  | ||
|  29th May 2011 8:06am |
| FG Member Since: 01 Apr 2011 Location: Somewhere on the Swedish East Coast Posts: 63      | Got my light bezels and mirror arms replaced under warranty two weeks ago.
 /FG | ||
|  30th May 2011 7:12am |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      |
 You can't make a silk purse out of a sow's ear and Land Rover has tried just that with the quality on certain items, as they are cr4p. Headlight bezels, sidesteps, front bumper, window hinge blocks, mud flap brackets, OEM A-bar brackets and wing mirror arms to name but a few. In my experience swapping out under warranty is just a 'sticking plaster fix' and the problem will undoubtedly reoccur sooner or later. I have either purchased quality after-market items or had the offending items removed and either chemically cleaned or blasted and a decent powder coating carried out for reasonable cost. (For example only £20 for a steering guard and A-bar brackets). Attention to detail is in my opinion what the Land Rover Quality Department lacks (if indeed there is such a department) and an eagle-eyed owner is much better placed to achieve the required standard of finish expected. For me I feel I am finally getting there after three years of ownership ironing out the minor issues myself.  If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  30th May 2011 10:02am |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472      |
 But that's hardly the point is it  The original parts should be fit for purpose in the first place  Steve. Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. | ||
|  30th May 2011 11:09am |
 I understand your frustration and your principle but unfortunately unless Land Rover are prepared to invest more time and money producing the quality customers deserve or listening to feedback you end up swapping things out under warranty until it expires, then eventually having to do something about it yourself! I personally do not have the patience, time or inclination to continually go back and forth to my dealers to have the same things continually exchanged due to inferior finish/quality when it can often be reolved in a single hit for minimum cost! One of the characteristics of owning a Defender I suppose. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  30th May 2011 12:42pm |
| Posting Rules
