Home > Puma (Tdci) > Found a loose switch
Tombte
Spain 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
I found this loosen switch over the transfer box of my Puma 2.4.
Do you recognize it? What's for?
Thanks.!
Post #733759 9th Oct 2018 9:03am
Hal
I believe it's the high-low detection switch electrical connector. Plugs into the other white connector hooked on the transfer box in your picture.
The other grey one at the top left had side (looks like it's all connected up ok) is the diff lock switch detection electrical connecton.
See page 674 of the Puma 2.4 w/s manual (available on this site if you search for it). Check for yourself before you plug anything in!
Post #733827 9th Oct 2018 2:23pm
Tombte
Thanks Hal.
I'll study the manual.
Post #733847 9th Oct 2018 4:26pm
Co1
Out of interest, it that the best way to refil transfer box oil I.e. from the top?
Post #733867 9th Oct 2018 7:33pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Not unless you never have a cubby box fitted... Or you have lots of time to spare or already need to remove the seat box centre section.
Much quicker to use a garden pressure sprayer from underneath to be honest... Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #733889 9th Oct 2018 8:20pm
Co1
Cheers!
Post #733895 9th Oct 2018 8:37pm
nickhodgson
Do your diff lock and handbrake lights work as its hard to see if they are connected or not? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #734061 10th Oct 2018 5:30pm
Tombte
Both work well.
Post #734781 15th Oct 2018 9:10am
hank
Could it be for the low range light? See here http://www.defender2.net/forum/topic50869.html
Post #734789 15th Oct 2018 10:14am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
This is normal on a MY2009, see that old post http://www.defender2.net/forum/topic13589.html “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #734798 15th Oct 2018 11:16am
Tombte
Thank you all for your replies.
Misterous switch... everything works, no plug to switch it, but sure it has or had it task...
Post #735476 18th Oct 2018 8:43am
