![]() | Home > Puma (Tdci) > Mysterious plug |
What year is the vehicle ?
I have a spare plug on my 2009 110 in the same location. It should be clipped to the gearbox and was removed in late 2010/2011 MY's. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 588 ![]() ![]() ![]() |
Ah, yes indeed, mine in MY2009! |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6008 ![]() ![]() ![]() |
Do 2009 MY Landies have a sensor for detecting when you engage low box? 1999 Defender TD5 110
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
I'm pretty sure that connector is C0100, for the driver's seat belt buckle switch, which isn't fitted to all markets.
There should be two wires - White/Purple and Black. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Thanks all for the replies!
I am pretty sure it does as engaging low ratio does change the ECU mapping and throttle sensitivity. It does not have any indicator on the dash though, but for sure the ECU can tell when the low ratio is engaged.
That would match what I can see, but hard to tell with certainty given the amount of Waxoil spread out in the area ![]() |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6346 ![]() ![]() ![]() |
Just looking at workshop manual and item 24 is the low range indicator ???.
Mine only seems to have diff lock indicator which comes on in low..... I presume this is normal? |
the diff lock light sort come on with diff locked in high or low range
Just done a search and been and checked all normal...no indicator for hi / low just for diff lock
