![]() | Home > For Sale & Wanted > [Wanted] Pre-Td5 blade fuse fusebox bracket |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6700 ![]() ![]() ![]() |
Before I cut and shut my glass fuse type to take the Tdi blade fuse holder, does anyone have a bracket?
![]() Click image to enlarge PRC8072 or AMR3138 ![]() ![]() |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
No but i have got a spare glass fuse (MY84) one on the old wiring loom if you want a spare to cut up?
Steve 02' 110 TD5 Double Cab Rebuild Thread |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
I might have one, will have a look tomorrow if that’s ok?
Please Nick. Thanks for the offer Steve but I've no issue with cutting the one I've got - no way it's ever going back to glass fuses
I've got the actual fusebox and terminals already and I think a swap to the Tdi type will be easier than the Td5 or Puma one
![]() Not that I'm shy of a wiring job ![]() ![]() ![]() |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Glass to blade fuse conversion is on my 'to-do' list, I got a full tdi loom and hacked it bits just for the fuse box
![]() Are you using special connectors? Or cut/solder/heat shrink? QRZ 2e0vpf Last edited by GREENI on 10th Oct 2018 3:40pm. Edited 1 time in total |
Animal
I bought this kit in February https://www.ebay.co.uk/itm/20-Way-Bulkhead...0873526036 February 2016 ![]() 3waycomponents still do the terminals on their own: https://www.3waycomponents.co.uk/Terminals...l-51101980 Pricey way to do it though ![]() ![]() ![]() |
Is this not for the Puma dashed-Td5-2.5TD conversion machine? I will look at the weekend I’m pretty sure I have at least one! Is the Td5 fuse box panel ok? I know I have one of those for sure.
Not going Puma dash in it, it's the testbed indeed but this is as much Puma as it's getting:
![]() Click image to enlarge ![]() ![]() |
Did you get sorted Martin? Been mega busy and this slipped my mind I came across the type below tonight in Work and went “ahhh crap I forgot all about that”
![]() ![]() ![]() Click image to enlarge The Puma loom that the savages cut the the ECU plugs off ![]() Click image to enlarge ![]() Click image to enlarge |
Same as I've already got thanks though Nick
![]() Why were the ECU plugs lopped off? ![]() ![]() |
Because it had the engine out and you know the easy way to remove the ECU then is to chop it off
![]() I’ve set an alarm on my phone to remind me to look tomorrow afternoon wen I get home from work. |
