Home > Puma (Tdci) > Refurbished Injectors - Are they worth it?
smb
Hopefully with the vast array of knowledge/experience/expertise on here I and others may be guided on the best route when replacing the Injectors.
It is probably just me, but having done many searches I cannot find a thread that gives advice on Injector renewal.
The costs are pretty eye watering depending on who you go to and there seems to be such big differences in costs. However, Im tempted to go down one of two routes.
The first is to get new ones from Turner Engineering, and the second is to get refurbished ones from Transit Parts UK.
What are peoples thoughts on these?
Many thanks
Post #732743 3rd Oct 2018 4:05pm
Bluest
What can be refurbished on these types of very high pressure injectors? I genuinely don't know, not being sarcastic. Is it more than just spraying them with carb cleaner to get the dirt off? 2007 110 TDCi Station Wagon XS
Post #732759 3rd Oct 2018 6:04pm
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
We have these guys down in Oz.
They fit new needles that are ceramic coated.
https://www.baileysdiesel.com/shop/bluepri...nder-2-4l/
Mark
Post #732833 3rd Oct 2018 10:54pm
Porny
Site Sponsor
I've never had any luck with recon injectors... times have moved on since tdi days, but a lot of recon places haven't.
For Tdci 2.4 or 2.2 I would always use new - which will also have the correct calibration code to put into the ECU.
No need to go genuine - just OEM. IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #732908 4th Oct 2018 12:55pm
smb
Hi Porny, Many thanks for your advice. Without putting you on the spot can you recommend a good supplier to get them from? Ive seen prices for new ones ranging from £ 180 to over £ 400 per injector!!
Many thanks again.
Post #732920 4th Oct 2018 1:50pm
Porny
Site Sponsor
I can do you brand new OEM injectors for £155 + vat each (if buying 4)
This includes all new seals. Only additional thing needed is 2 new clamp bolts which are £8 + vat a pair
You will need to get the injectors coded into the ECU once fitted and Pilot Learn redone.
Fitting is easy - as long as the old injectors come out.
Ian IRB
Post #732923 4th Oct 2018 1:57pm
smb
Hi Ian,
PM on its way.
Many thanks
Steve
Post #732928 4th Oct 2018 2:49pm
keath
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
Ian
If you don't mind me asking, where from?
Post #734759 15th Oct 2018 5:28am
Porny
Site Sponsor
Keath - from me. Drop me a PM if needed.
Regards
Ian IRB
Post #734815 15th Oct 2018 12:27pm
I can vouch for Porny's work if needed Thumbs Up QRZ 2e0vpf
Post #734854 15th Oct 2018 4:45pm
keath
Regards
Ian
Hi Ian,
Check your PM's.
Cheers.
Post #739954 11th Nov 2018 10:37pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Definately go new Ian at IRB can do them at a decent price circa 120-130 iirc 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #739960 11th Nov 2018 11:29pm
Cupboard
Ian @ IRB is Porny, above.
Post #739969 12th Nov 2018 12:25am
Merlin
Would you be able to quote part numbers?
Ian
Cheers,
Peter
Post #740027 12th Nov 2018 12:59pm
OldDD
Isle Of Man 2012 Defender 90 Puma 2.2 HT Orkney Grey
Porny
I'd be keen to know more about the Injectors you offer - Can you pm me the spec please??
Do you have them in stock??
Post #746290 18th Dec 2018 1:38pm
